I bought a laptop from Cyberpower about 3 months ago. I realised when looking at my temps while gaming my CPU can go up to 95C. I've got an external fan (similar to this) but it doesn't seem to help. My GPU seems to say at 80C max which (from what I understand) is fine. Are those ok for a laptop? If not, what can I do to try and keep it cooler?
Thanks for your help!
CPU-Intel I7-8750H
GPU-RTX 2070
https://linustechtips.com/topic/1106400-extremely-hot-cpu/
Thats normal for laptops to reach very high CPU temps under load. While hot, laptop chips are designed to go that high and will throttle itself to maintain thermals.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1106400-extremely-hot-cpu/#findComment-12908142
Performance laptops will run hotter, as @Skiiwee29 said, with a few exceptions.
The best thing you can do is make sure your intake and exhaust ports have access to space to do their respective jobs.
You can also try some undervolting if you'd like, it'll be functionally similar to overclocking, finding a voltage where you're stable at a given frequency is your goal, though your mileage may vary for this.
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
https://linustechtips.com/topic/1106400-extremely-hot-cpu/#findComment-12908155
So it shouldn't damage the CPU then?
I've propped it up as well now which should hopefully help and I'll look into undervolting. Thanks!
https://linustechtips.com/topic/1106400-extremely-hot-cpu/#findComment-12908176
Short term no, but if prolonged exposure to that type of heat (talking months/years for hours on end per day), it will likely shorten the life span on the chip.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1106400-extremely-hot-cpu/#findComment-12908186
Using ThrottleStop, I went down by 130 mV (the most i could go without my computer crashing) but it doesn't seemed to have done much. Anything else I can do or will I just have to deal with it?
https://linustechtips.com/topic/1106400-extremely-hot-cpu/#findComment-12910904
