CPU Power Connector 8pin
Solved by Fasauceome,
7 minutes ago, vSyNd1c4t3 said:just isntalled a Stock Intel Cooler, and it seems to squish around a bit, not a tight secure, is this normal for stock intel coolers?
Depends on what you mean, but overall it is not normal to "squish" around, it should be very secure. BIOS temperature means nothing, load temps matter.
8 minutes ago, vSyNd1c4t3 said:t's an i5-6500 with a TDP of 65w. so I should be good based on what your guys are saying?
not "you should be good," just "it will be functional on a basic level." I would not put my faith in that power supply by any means, not in a system I care about.
