Need help choosing between either Razer or Corsair
Razer or Corsair for getting my PC set up. Razer seems to have more integration and I want something that may possibly integrate into my RGB if I get a motherboard or so with RGB
Razer in general makes shittier products whether it be their cheap feeling cherry knock of keyboard switches, their oversized mice, their low quality headphones Corsair in general makes better products and still has a solid RGB software. In terms of customer support, corsair easily takes the cake with customer support, the last time I ever used Razer is when they refused to replace a broken keycap that broke when taking it off to clean (razers low build quality was at fault), they insisted that "they are not designed to be taken off to clean".
While Corsair isn't AMAZING in my eyes, they make really good PC parts and nice keyboards and mouses to back them up. Razer seems to only care about their RGB and not QC or customer support. I should also add how f*cking overpriced Razer's prouducts are.
idk tbh
I definitely wouldn't get Razer.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
i definitely chose Corsair or Logitech
  Spec: Macbook Air 2017
ProcessorPU: ii5 (I5-5350U |
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
 | GPU: Intel HD 6000 |
| Audio: JBL 450BT Wireless Headset |
23 hours ago, LukeSavenije said:
there's more than just those two...
What do you suggest?
Leopold, (no RGB but the quality is great), Filco,CoolerMaster or Ducky.
I would have gone with SteelSeries they have the most reliable essentials you can find in the market.
I have steelseries mouse now, and had many of their stuff over the years, so no, they don't.
It depends where. For Corsair, you can use iCUE/Link (I forget which is for PC parts and which is for peripherals) to sync up a Corsair mouse, headset, keyboard, RAM, fans, and an AIO. I would argue Corsair have more integration in that sense.
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
Usually you should go for models and not brands... you'll find good and bad models on any brand.
That said, Razer is garbage, I'd go Corsair in a blink :P
Personal Desktop":
Luna, the temporary Desktop:
iCUE does everything now, I think it has Link built in if you want everything to work like one big RGB strip, or you set them individually like normal. It can be buggy sometimes if you have say, an Asus board with AURA RGB and then Corsair RGB RAM, the two will fight over who controls the RAM. Aside from that it's pretty decent.
Main PC
CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset
Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads
Motherboard: EVGA X299 Dark
RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16
GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block
Storage:  1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo
Optical Drives: LG WH14NS40
PSU: EVGA 1600W T2
Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
Honestly, I've gone on a keyboard buying spree, is there a specific switch that you like over the others?
Would this be your first mechanical keyboard?
You may want to go for the Glorius GMMK keyboard, excellent value and you can customize it anyway you want. Unless you want cherry switches.
Current Build
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
  • Mouse
  • Sound
  • Operating System
If you want RGB, Ducky or Cooler Master keyboards are the better choices than Corsair ones. Otherwise customize one for yourself with no limits.
SILVER GLINT
CPU: AMD Ryzen 7 3700X || Motherboard: Gigabyte X570 I Aorus Pro WiFi || Memory: G.Skill Trident Z Neo 3600 MHz || GPU: Sapphire Radeon RX 5700 XT || Storage: Intel 660P Series || PSU: Corsair SF600 Platinum || Case: Phanteks Evolv Shift TG Modded || Cooling: EKWB ZMT Tubing, Velocity Strike RGB, Vector RX 5700 +XT Special Edition, EK-Quantum Kinetic FLT 120 DDC, and EK Fittings || Fans: Noctua NF-F12 (2x), NF-A14, NF-A12x15
*Deleted as accidental double post.
Damn crappy connection..*
SILVER GLINT
