Using Range Extender To Increase Speed Over WiFi
13 minutes ago, Midevil Chaos said:Anywhere in the apartment, my speed according to Ookla is 50 Mbps over WiFi. Now, if I plug my laptop into the router via my cat5 cable, it's roughly doubled ~100 Mbps. So, I was wondering, if I bought this range extender seen below (which have Ethernet ports) and hooked up my laptop to one of the Ethernet ports, would my download speed increase to ~100 Mbps since it would be tethered to the range extender? Here is the one I may want to buy:
So essentially you want to use it in Client Mode?
You'll still be limited to 50Mbps as the Extender is still relying on the WiFi connection from your router. What you should really look into is a Ethernet Switch so you can "extend" the length of your wired connection. It's not exactly what a switch was designed for but it will work. But depending on the lay out of your house/apartment, that might not be preferable.
