Hi, Im building a computer, I have:
Gigabyte Aorus Gaming wifi Z370
Rosewill 750w 80+ semi modular
Intel i7 8700k
Radeon Vega 56 Sapphire
Seagate 3Tb HDD
Skynix 256gb SSD X 2
16gb Ram Viper 2400Mhz
Cooler Master 220mm water cooler
I haven’t bought a case yet Im just trying everything out of their boxes to see if they work.
I installed everything and try to boot with a screwdriver. When I power on the switch on the psu I get a blink, everything on the bord light up for a second and go off (wich is normal). But when ai go ahead and power on the motherboard, I get nothing at all, just a red blink on a led. The fans won’t spin (even the one in the psu). No light whatsoever.
I decided to remove everything and leave only the power supply (24 and 8 pins) and the processor in the motherboard. I tried again, and same results. Red blink for less then a sec in the vga led and that’s it. The power supply and the motherboard are new, the cpu was working in another computer.
Im thinking if the problem was only the cpu, the motherboard would power on and let me know that right?
What did I do wrong?
How can I get it fixed?
I have uploaded pictures of what happens.
I think you in advance for you help!
https://linustechtips.com/topic/1060595-help-please/
wait did you just put a functioning motherboard on top of a carpet?
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1060595-help-please/#findComment-12536079
You have no RAM installed for one so it won't even POST. You need at least 1 stick of RAM installed.
The PSU fan will not spin by default unless it's under a certain load.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/1060595-help-please/#findComment-12536083
1. You have no RAM
2. Are you seriously testing this with your motherboard sitting on bare carpet?!?!?!?!?!?!!!!!!!!!11111111eleven
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/1060595-help-please/#findComment-12536089
There's a fun little acronym for describing the pain your pictures give me:
Put
Your
System
On
A
Damn
Cardboard
Box
Before
Turning
It
On
Otherwise known as PYSOADCBBTIO
Really rolls off the tongue
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1060595-help-please/#findComment-12536090
STOP NAOWWWW
Google Breadboarding, your doing it wrong, your going to hurt your stuff - Add RAM stick
You may be shorting it out by doing this wrong, which would cause the PSU to IMMEDIATLY power down.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1060595-help-please/#findComment-12536098
1 minute ago, JoshHT said:
Ok even with the RAM it does not POST
Put it on top of the box, and put the box on top of a wooden table. There's a chance your motherboard has badly shorted itself and is borked already.
https://linustechtips.com/topic/1060595-help-please/#findComment-12536100
Put
Your
System
On
A
Damn
Cardboard
Box
Before
Turning
It
On
I put it on the motherboar’s cardboard
https://linustechtips.com/topic/1060595-help-please/#findComment-12536105
Excellent. Any different result? With ram in various slots?
Edit: you might need a cpu fan to turn on the PC because CPUs don't like being uncovered
Primary PC:
PSU tier list
https://linustechtips.com/topic/1060595-help-please/#findComment-12536107
Yes. I put the ram, removed the motherboard safely and carefully from the carpet and tried again. But as in the picture. I just get the red blink in the vga led
Do you have a motherboard speaker you can hook up? That will give you a beep code you can use to identify the problem.
If you haven't already, make sure the RAM is in the slot farthest from the CPU socket.
https://linustechtips.com/topic/1060595-help-please/#findComment-12536115
what slots did you put it in  generally motherboards want it in 2 and 4
https://linustechtips.com/topic/1060595-help-please/#findComment-12536117
Not gonna lie, I wear socks and moonwalk while putting my PCs together...but this looks to be much...much...more unsafe.
https://linustechtips.com/topic/1060595-help-please/#findComment-12536118
1 minute ago, Sorenson said:
Make sure your ram is in the correct slots, and instal your cpu cooler. If that still doesn't work the do a CMOS reset.
A board will POST without a cooler. It's just a really bad idea to let it run any longer than it takes to get to the POST screen without having a cooler sitting on top of the CPU.
https://linustechtips.com/topic/1060595-help-please/#findComment-12536121
I bought one, it supposed to come today. Im still waiting on it
https://linustechtips.com/topic/1060595-help-please/#findComment-12536124
