Sleeved Cables vs Stock Cables
valvoa
Hello all,
I'm looking for a bit of feedback. I've read many unpleasant reviews regarding sleeved cable extensions frying GPU's and not being reliable so I'm leaning more towards fully sleeved cables. Question is how reliable are sleeved cables such as CableMod vs the stock cables you PSU comes with? Mine being Corsair RM750x Cables.
Is there a chance with even fully sleeved cables that they might be unreliable or even have the potential to fry your GPU? 100 bucks for the pro Cablemod line isn't cheap but are they worth it in terms of safety and quality? Also what do you use? Thanks!
You shouldn't need it if you've got a good PSU like the one you have. It's probably just for some very specific cheap ass PSUs
My bad, I don't actually need the sleeved cables I just would like it to look a little cleaner then the stock cables. Corsair GPU cables especially are super bulky and don't look the greatest, but I'm concerned about the stability of 3rd party cables.
As long as it's from a high quality manufacturer, it will be great. Cable Mod does make some good cables and they should have warranty if they fail
The fried GPUs are probably from people using messed up extensions or they are blaming their PSU killing shit on the extensions. Cablemod is safe, just make sure you get cables that fit your PSU by selecting the right one before you order :)
Builds:
Are extensions safe as well or should I only be considering full cables? Thanks
Extensions are fine generally, but ebay ones are unknown quality.
Builds:
