So, this Christmas (2019), I plan on getting a MacBook for travel, school, homework, work in general, etc. uses.
Now I live in Canada, so prices are HIGH AFFFFF!!
But other than prices, I need help deciding what is better?
I'm stuck between these (also keep in mind I'm keeping it equal price, 1.749)
MacBook (original), Air, Pro
1.2GHz dual-core 7th-generation Intel Core m3 processor, Turbo Boost up to 3.0GHz
8GB 1866MHz LPDDR3 memory
256GB SSD storage
Intel HD Graphics 615
12" (inch) MacBook that weighs basically 2 pounds (good for travelling, school, etc.) & is SUPER light.
Price in CA is $1.729
NEXT
1.6GHz dual‑core 8th‑generation Intel Core i5 processor, Turbo Boost up to 3.6GHz
Retina display
8GB 2133MHz LPDDR3 memory
256GB SSD storage
Intel UHD Graphics 617
Touch ID
Force Touch trackpad
Two Thunderbolt 3 ports
13" (inch) MacBook AIR, weighs around 3-4 pounds & is pretty good for travelling.. kind of like carrying an iPad w/ other accessories.
Price in CA is $1.749
(IMPORTANT: This is 256GB SSD, while the other MacBook AIR that is 128GB SSD for $1.499 CA, so I might actually buy that instead, but for the sake of this, keeping it same price. $1749)
NEXT & last
2.3GHz dual-core 7th-generation Intel Core i5 processor, Turbo Boost up to 3.6GHz
Intel Iris Plus Graphics 640
128GB SSD storage
Same price as CA $1.749
GUESSING at least 5+ pounds, which is unnecessary for travelling because of weight, but okay.
NOW, I just need help choosing which one i should get..
I like the original MacBook because of it's light weight & it is 256GB SSD, which is probably enough for productivity, photoshop, editing, etc.
I like the MacBook AIR because it has a little more GHZ (like 0.6 extra) & touch ID BUT, BUT weighs a little extra
The MacBook Pro because at least 1 GHZ more than the AIR, but CONS are weighs a bit more, less SSD space, and thats it.
I only posted this thread just because I'm having difficulties choosing. But I think it'll either be original MacBook or AIR. You guys throw some suggestions of what you would take :)
PLEASE NOTE
(If I bought air, I would buy the one with 128GB SSD for CAD $1.499 just because it's cheaper, but IDK if that is enough SSD space)
https://linustechtips.com/topic/1059194-need-help-deciding-apple-laptops/
5 minutes ago, smilevi said:
Do you 1000% need MacOS beyond any other reason like having decent hardware that won't overheat for the same price and an easily replaceable SSD?
Now I don't know macbooks, but if you need storage grab the second one, if you need speed grab the third, if you are willing to get a non Apple laptop and battery life is not that great of an issue you would probably be better served by the ASUS FX504 as it is a much faster laptop for the money, also do note that all of those macbooks have the butterfly key which may lead to some serious issues in the near future.
In search of the future, new tech, and exploring the universe! All under the cover of anonymity!
i would just personally search around for a good deal on a windows laptop
F@H [] Autobiography []
Main Desktop and Folding Rig :
Cpu : I5-9400f
Gpu : GTX 1070 Founder's Edition
Psu : Seasonic G-650
Ram : G.Skill Aegis 4x8gb DDR4 2666MHz (14-15-15-34)
External Storage : 8tb Western Digital Elements Usb 3.0 Hard Drive
Storage : Samsung 970 Evo 500GB
Motherboard : ASUS B365 Pro-4 m
Gaming Laptop :
Cpu : I7-8750H 2.2ghz
Gpu : GTX 1070 Max Q
Psu : laptop b r i c k
Ram : 16gb 2666Mhz
Storage : 512Gb SATA SSD
Motherboard : it's a laptop.....
old boomer (currently non-functional)
Cpu : I5-6400 2.7ghz (doesn't have a heatsink)
Gpu : Asus RX580 8gb (might sell)
Psu : EVGA 500 watt 80 plus
Ram : 16gb DDR3 1400mhz
Storage : 1tb Toshiba HDD (currently in main pc)
Motherboard : Generic ASUS pre-built motherboard
Macbook Air, IMO
The Macbook has display cable issues, and a VERY fragile logic board
The Macbook Pro is the cheapest, last gen model and lacks usable storage amounts (and storage is unchangeable on the 2017 model as well as the 2018 iirc)
Macbook Air is lower specs than the MBP, but the best device by far given its higher storage. It is even fine for video editing due to Intel Quicksync acceleration if that's what you do. It is what I do, so I had to mention it.
If you could afford a modern 4 TB3 port Macbook Pro 13, I would advise that. But the one you mentioned simply doesn't deserve to exist.
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
3 hours ago, Saksham said:
you said macbook school? like high school or college? did you consider that most of the time, apps may not have macOS compatibility?
I'm unaware of a situation where macOS does not have a compatible app for a given task.
Useful threads:
Total: $1891.98
in many cases (espesally for engineering classes, the CAD software or other softwares does not support mac).
for example: autodesk inventor does have a mac version, but it is highly limited in capability and usability.
Edited by Saksham
If OP were an engineering student, he would be foolish for looking at anything less than a portable workstation like the Thinkpad P52.
If I had to guess, he is around the age/schooling of a college freshman. In which case he will need nothing more than Office 365 and Google Chrome.
Useful threads:
Total: $1891.98
18 hours ago, SenpaiKaplan said:
Macbook Air, IMO
Alright, a couple of questions right off the bat..
For the current MacBook Air I'm looking at, it has 8GB RAM & 256GB SSD..
Now I'm wondering, for school work, photoshop, editing, etc.. is that even enough space for saving all of those?
Because where I live (canada), the prices for RAM & SSD is like $240 CAD and upper, so any upgrades would go over $2000 cad
That would be fine for a while, but I would recommend keeping a large external drive at home (or using a portable SSD) in order to maximize space.
Though, above all, do your best to save for a tier with higher storage especially. 8GB RAM is fine for the foreseeable future.
Useful threads:
Total: $1891.98
