Posted April 8, 2019 i will soon be building this new system since I got all the parts that are needed. However. This Motherboard which is the Gigabyte Z390 Aurus Master. It has 2 8 Pin CPU Power Plugs. But my LEPA 850w PSU only has 1. Will that be an issue with this board if its only connected using the 1 CPU 8 Pin Power cable? CPU: I9-9900k CPU Cooler: Noctua NH-D15 Memory: 32GB Corsair Vengeance LPX 3200mhz Dual Channel Motherboard: Gigabyte Z390 Aorus Master Soundcard: Sound BlasterX AE-7 Capture Card: Elgato Game Capture HD60 Pro Graphics Card: Gigabyte RTX 3080 Ti Boot Drive: Samsung 980 Pro NVME 1TB SSD Storage Drives: WD BLACK SN750 NVME 1TB SSD WD Blue 1TB SSD, Samsung 850 Pro 512GB SSD, 2 WD Blue 500GB SSDs Blu-Ray Drive: Pioneer BDR-2207 Power Supply: Seasonic PRIME 850 Platinum SSR-850PD 850W 80+ Platinum Case: Cooler Master HAF X OS: Windows 10 Pro Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 8, 2019 The motherboard and CPU will be fully functional with only 8 CPU pins, but why did you shell out so much for an extreme OC board if not to do an extreme OC? And what CPU will this be accompanied by? I WILL find your ITX build thread, and I WILL recommend the SIlverstone Sugo SG13B Primary PC: i7 8086k - EVGA Z370 Classified K - G.Skill Trident Z RGB - WD SN750 - Jedi Order Titan Xp - Hyper 212 Black (with RGB Riing flair) - EVGA G3 650W - dual booting Windows 10 and Linux - Black and green theme, Razer brainwashed me. Draws 400 watts under max load, for reference. How many watts do I need? ATX 3.0 & PCIe 5.0 spec, PSU misconceptions, protections explained, group reg is bad Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 8, 2019 The second CPU power connector is as useless as RGB. Don't worry about it. :) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 8, 2019 You typically only need one of them. The other is normally for extra power when overclocking. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 8, 2019 Author 4 minutes ago, fasauceome said: The motherboard and CPU will be fully functional with only 8 CPU pins, but why did you shell out so much for an extreme OC board if not to do an extreme OC? And what CPU will this be accompanied by? I don't plan on doing any extreme overclocking. also This motherboard was recommended in a lot of places due to how it cools its VRMs and such. Plus has tons of features. Also this board will be using a 9900k. CPU: I9-9900k CPU Cooler: Noctua NH-D15 Memory: 32GB Corsair Vengeance LPX 3200mhz Dual Channel Motherboard: Gigabyte Z390 Aorus Master Soundcard: Sound BlasterX AE-7 Capture Card: Elgato Game Capture HD60 Pro Graphics Card: Gigabyte RTX 3080 Ti Boot Drive: Samsung 980 Pro NVME 1TB SSD Storage Drives: WD BLACK SN750 NVME 1TB SSD WD Blue 1TB SSD, Samsung 850 Pro 512GB SSD, 2 WD Blue 500GB SSDs Blu-Ray Drive: Pioneer BDR-2207 Power Supply: Seasonic PRIME 850 Platinum SSR-850PD 850W 80+ Platinum Case: Cooler Master HAF X OS: Windows 10 Pro Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 8, 2019 Just now, TigerClaw said: I don't plan on doing any extreme overclocking. also This motherboard was recommended in a lot of places due to how it cools its VRMs and such. Plus has tons of features. Also this board will be using a 9900k. Oh yes the VRMs will be quite cool, on account of the overbuilt power delivery not at all flexing its muscle. At least it is a pretty killer board, I hope at some point you get to take advantage of all its great features. I WILL find your ITX build thread, and I WILL recommend the SIlverstone Sugo SG13B Primary PC: i7 8086k - EVGA Z370 Classified K - G.Skill Trident Z RGB - WD SN750 - Jedi Order Titan Xp - Hyper 212 Black (with RGB Riing flair) - EVGA G3 650W - dual booting Windows 10 and Linux - Black and green theme, Razer brainwashed me. Draws 400 watts under max load, for reference. How many watts do I need? ATX 3.0 & PCIe 5.0 spec, PSU misconceptions, protections explained, group reg is bad Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 8, 2019 Author 5 minutes ago, Oshino Shinobu said: You typically only need one of them. The other is normally for extra power when overclocking. Can you do some mild overclocking with just one 8 Pin CPU power. By just having it boost to 5Ghz automatically? CPU: I9-9900k CPU Cooler: Noctua NH-D15 Memory: 32GB Corsair Vengeance LPX 3200mhz Dual Channel Motherboard: Gigabyte Z390 Aorus Master Soundcard: Sound BlasterX AE-7 Capture Card: Elgato Game Capture HD60 Pro Graphics Card: Gigabyte RTX 3080 Ti Boot Drive: Samsung 980 Pro NVME 1TB SSD Storage Drives: WD BLACK SN750 NVME 1TB SSD WD Blue 1TB SSD, Samsung 850 Pro 512GB SSD, 2 WD Blue 500GB SSDs Blu-Ray Drive: Pioneer BDR-2207 Power Supply: Seasonic PRIME 850 Platinum SSR-850PD 850W 80+ Platinum Case: Cooler Master HAF X OS: Windows 10 Pro Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 8, 2019 Just now, TigerClaw said: Can you do some mild overclocking with just one 8 Pin CPU power. By just having it boost to 5Ghz automatically? Anything that's not LN2 is fine with a single 8-pin. As I said, it's as useless as RGB, and does equally much for performance. :) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 8, 2019 Author 1 minute ago, fasauceome said: Oh yes the VRMs will be quite cool, on account of the overbuilt power delivery not at all flexing its muscle. At least it is a pretty killer board, I hope at some point you get to take advantage of all its great features. Yeah. But the ambient temperatures in my room would not be good for Overclocking this day. on really hot days. Especially here in Florida. Temps right now is at 86F / 30C CPU: I9-9900k CPU Cooler: Noctua NH-D15 Memory: 32GB Corsair Vengeance LPX 3200mhz Dual Channel Motherboard: Gigabyte Z390 Aorus Master Soundcard: Sound BlasterX AE-7 Capture Card: Elgato Game Capture HD60 Pro Graphics Card: Gigabyte RTX 3080 Ti Boot Drive: Samsung 980 Pro NVME 1TB SSD Storage Drives: WD BLACK SN750 NVME 1TB SSD WD Blue 1TB SSD, Samsung 850 Pro 512GB SSD, 2 WD Blue 500GB SSDs Blu-Ray Drive: Pioneer BDR-2207 Power Supply: Seasonic PRIME 850 Platinum SSR-850PD 850W 80+ Platinum Case: Cooler Master HAF X OS: Windows 10 Pro Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 8, 2019 1 minute ago, TigerClaw said: Yeah. But the ambient temperatures in my room would not be good for Overclocking this day. on really hot days. Especially here in Florida. Temps right now is at 86F / 30C Even boards at half the price would survive that ambient, but at the very least the vrm on that board would get away with lower voltages than normal for a mild OC (for an i9) to give you the cool temp peace of mind. I WILL find your ITX build thread, and I WILL recommend the SIlverstone Sugo SG13B Primary PC: i7 8086k - EVGA Z370 Classified K - G.Skill Trident Z RGB - WD SN750 - Jedi Order Titan Xp - Hyper 212 Black (with RGB Riing flair) - EVGA G3 650W - dual booting Windows 10 and Linux - Black and green theme, Razer brainwashed me. Draws 400 watts under max load, for reference. How many watts do I need? ATX 3.0 & PCIe 5.0 spec, PSU misconceptions, protections explained, group reg is bad Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 8, 2019 Author Just now, fasauceome said: Even boards at half the price would survive that ambient, but at the very least the vrm on that board would get away with lower voltages than normal for a mild OC (for an i9) to give you the cool temp peace of mind. I also have a Cooler Master HAF X which my currennt system is using. It will no doubt provide good air flow for this new system. CPU: I9-9900k CPU Cooler: Noctua NH-D15 Memory: 32GB Corsair Vengeance LPX 3200mhz Dual Channel Motherboard: Gigabyte Z390 Aorus Master Soundcard: Sound BlasterX AE-7 Capture Card: Elgato Game Capture HD60 Pro Graphics Card: Gigabyte RTX 3080 Ti Boot Drive: Samsung 980 Pro NVME 1TB SSD Storage Drives: WD BLACK SN750 NVME 1TB SSD WD Blue 1TB SSD, Samsung 850 Pro 512GB SSD, 2 WD Blue 500GB SSDs Blu-Ray Drive: Pioneer BDR-2207 Power Supply: Seasonic PRIME 850 Platinum SSR-850PD 850W 80+ Platinum Case: Cooler Master HAF X OS: Windows 10 Pro Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 8, 2019 Author On my current system which is a 3930k. I have Turbo enabled which boost the CPU from 3.20Ghz to 3.8Ghz. I plan on doing the same with this new system. Just turning on the Turbo Mode. and it just goes to 5Ghz on one or two of the cores. Should I leave Multicore Enhancement enabled or disabled? for someone who isn't overclocking. What do you recommend? This board is overkill for my needs. But its nice to have all those features. Should you ever want to dabble on it. But I think that's the whole point of my new build. Overkill. Because I want something that does everything. CPU: I9-9900k CPU Cooler: Noctua NH-D15 Memory: 32GB Corsair Vengeance LPX 3200mhz Dual Channel Motherboard: Gigabyte Z390 Aorus Master Soundcard: Sound BlasterX AE-7 Capture Card: Elgato Game Capture HD60 Pro Graphics Card: Gigabyte RTX 3080 Ti Boot Drive: Samsung 980 Pro NVME 1TB SSD Storage Drives: WD BLACK SN750 NVME 1TB SSD WD Blue 1TB SSD, Samsung 850 Pro 512GB SSD, 2 WD Blue 500GB SSDs Blu-Ray Drive: Pioneer BDR-2207 Power Supply: Seasonic PRIME 850 Platinum SSR-850PD 850W 80+ Platinum Case: Cooler Master HAF X OS: Windows 10 Pro Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 8, 2019 28 minutes ago, TigerClaw said: i will soon be building this new system since I got all the parts that are needed. However. This Motherboard which is the Gigabyte Z390 Aurus Master. It has 2 8 Pin CPU Power Plugs. But my LEPA 850w PSU only has 1. Will that be an issue with this board if its only connected using the 1 CPU 8 Pin Power cable? The PSU should have 2 CPU power cables. i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium. i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W. i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 8, 2019 13 minutes ago, TigerClaw said: On my current system which is a 3930k. I have Turbo enabled which boost the CPU from 3.20Ghz to 3.8Ghz. I plan on doing the same with this new system. Just turning on the Turbo Mode. and it just goes to 5Ghz on one or two of the cores. Should I leave Multicore Enhancement enabled or disabled? for someone who isn't overclocking. What do you recommend? This board is overkill for my needs. But its nice to have all those features. Should you ever want to dabble on it. But I think that's the whole point of my new build. Overkill. Because I want something that does everything. You are purchasing things based on reasoning that is not supporting of the purchase. What are these features that are nice to have but other boards don't? Turbo mode is what EVERY CPU does by itself on even cheap motherboards with stock cooling. You're buying a Ferrari and driving it in on city streets, but not the Autobahn. Nutshell: People are trying to save you money to get you almost the same performance, or use the uber stuff you bought to get max out of it. You should listen to them. "Do what makes the experience better" - in regards to PCs and Life itself. Onyx : AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502 7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU - Cooler Master MasterBox Q300L - Samsung 27" 1080p Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p Steam Deck 512GB OLED OnePlus: OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green OnePlus Buds Pro 2 - Eternal Green Other Tech: - 2021 Volvo S60 Recharge T8 Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified. - Lenovo 720S Touch 15.6" - i7 7700HQ, 16GB RAM 2400MHz, 512GB NVMe SSD, 1050Ti, 4K touchscreen - MSI GF62 15.6" - i7 7700HQ, 16GB RAM 2400 MHz, 256GB NVMe SSD + 1TB 7200rpm HDD, 1050Ti - Ubiquiti Amplifi HD mesh wifi Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 8, 2019 Author 3 minutes ago, Ankerson said: The PSU should have 2 CPU power cables. I have this PSU that I bought way back in 2012.. https://www.newegg.com/Product/Product.aspx?Item=N82E16817494009 And looking at the Specs. You're right about that. It does have a 2nd CPU Power connector. 1 x 4+4pin CPU1 x 8pin CPU CPU: I9-9900k CPU Cooler: Noctua NH-D15 Memory: 32GB Corsair Vengeance LPX 3200mhz Dual Channel Motherboard: Gigabyte Z390 Aorus Master Soundcard: Sound BlasterX AE-7 Capture Card: Elgato Game Capture HD60 Pro Graphics Card: Gigabyte RTX 3080 Ti Boot Drive: Samsung 980 Pro NVME 1TB SSD Storage Drives: WD BLACK SN750 NVME 1TB SSD WD Blue 1TB SSD, Samsung 850 Pro 512GB SSD, 2 WD Blue 500GB SSDs Blu-Ray Drive: Pioneer BDR-2207 Power Supply: Seasonic PRIME 850 Platinum SSR-850PD 850W 80+ Platinum Case: Cooler Master HAF X OS: Windows 10 Pro Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 8, 2019 Just now, TigerClaw said: I have this PSU that I bought way back in 2012.. https://www.newegg.com/Product/Product.aspx?Item=N82E16817494009 And looking at the Specs. You're right about that. It does have a 2nd CPU Power connector. 1 x 4+4pin CPU1 x 8pin CPU Yeah, use both connections. i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium. i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W. i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 8, 2019 Author 1 minute ago, jstudrawa said: You are purchasing things based on reasoning that is not supporting of the purchase. Turbo mode is what EVERY CPU does by itself on even cheap motherboards with stock cooling. You're buying a Ferrari and driving it in on city streets, but not the Autobahn. Well I will have a system that will last me for a couple of years. CPU: I9-9900k CPU Cooler: Noctua NH-D15 Memory: 32GB Corsair Vengeance LPX 3200mhz Dual Channel Motherboard: Gigabyte Z390 Aorus Master Soundcard: Sound BlasterX AE-7 Capture Card: Elgato Game Capture HD60 Pro Graphics Card: Gigabyte RTX 3080 Ti Boot Drive: Samsung 980 Pro NVME 1TB SSD Storage Drives: WD BLACK SN750 NVME 1TB SSD WD Blue 1TB SSD, Samsung 850 Pro 512GB SSD, 2 WD Blue 500GB SSDs Blu-Ray Drive: Pioneer BDR-2207 Power Supply: Seasonic PRIME 850 Platinum SSR-850PD 850W 80+ Platinum Case: Cooler Master HAF X OS: Windows 10 Pro Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 8, 2019 Just now, TigerClaw said: Well I will have a system that will last me for a couple of years. Uhm yeah you will. Pretty final statement from a closed mind. Enjoy it, it's a beast. "Do what makes the experience better" - in regards to PCs and Life itself. Onyx : AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502 7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU - Cooler Master MasterBox Q300L - Samsung 27" 1080p Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p Steam Deck 512GB OLED OnePlus: OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green OnePlus Buds Pro 2 - Eternal Green Other Tech: - 2021 Volvo S60 Recharge T8 Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified. - Lenovo 720S Touch 15.6" - i7 7700HQ, 16GB RAM 2400MHz, 512GB NVMe SSD, 1050Ti, 4K touchscreen - MSI GF62 15.6" - i7 7700HQ, 16GB RAM 2400 MHz, 256GB NVMe SSD + 1TB 7200rpm HDD, 1050Ti - Ubiquiti Amplifi HD mesh wifi Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 8, 2019 Author 1 minute ago, Ankerson said: Yeah, use both connections. yeah. Will probably do that. Should I ever play around with overclocking. I hope the Phanteks PH-TC14PE can handle a 9900k. CPU: I9-9900k CPU Cooler: Noctua NH-D15 Memory: 32GB Corsair Vengeance LPX 3200mhz Dual Channel Motherboard: Gigabyte Z390 Aorus Master Soundcard: Sound BlasterX AE-7 Capture Card: Elgato Game Capture HD60 Pro Graphics Card: Gigabyte RTX 3080 Ti Boot Drive: Samsung 980 Pro NVME 1TB SSD Storage Drives: WD BLACK SN750 NVME 1TB SSD WD Blue 1TB SSD, Samsung 850 Pro 512GB SSD, 2 WD Blue 500GB SSDs Blu-Ray Drive: Pioneer BDR-2207 Power Supply: Seasonic PRIME 850 Platinum SSR-850PD 850W 80+ Platinum Case: Cooler Master HAF X OS: Windows 10 Pro Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 8, 2019 1 minute ago, TigerClaw said: yeah. Will probably do that. Should I ever play around with overclocking. I hope the Phanteks PH-TC14PE can handle a 9900k. Should be fine. i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium. i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W. i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 8, 2019 Author 1 minute ago, jstudrawa said: Uhm yeah you will. Pretty final statement from a closed mind. Enjoy it, it's a beast. Maybe I was overthinking when I came up with this build. But I needed something that will let me do the things. Should I ever want to play with them. For me. It doesn't make any sense getting a system that doesn't have overclocking features. Because what if one day i want to play around with that. and then being bummed that the board doesn't support that. Right? Its better to future proof yourself. CPU: I9-9900k CPU Cooler: Noctua NH-D15 Memory: 32GB Corsair Vengeance LPX 3200mhz Dual Channel Motherboard: Gigabyte Z390 Aorus Master Soundcard: Sound BlasterX AE-7 Capture Card: Elgato Game Capture HD60 Pro Graphics Card: Gigabyte RTX 3080 Ti Boot Drive: Samsung 980 Pro NVME 1TB SSD Storage Drives: WD BLACK SN750 NVME 1TB SSD WD Blue 1TB SSD, Samsung 850 Pro 512GB SSD, 2 WD Blue 500GB SSDs Blu-Ray Drive: Pioneer BDR-2207 Power Supply: Seasonic PRIME 850 Platinum SSR-850PD 850W 80+ Platinum Case: Cooler Master HAF X OS: Windows 10 Pro Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 8, 2019 28 minutes ago, TigerClaw said: On my current system which is a 3930k. I have Turbo enabled which boost the CPU from 3.20Ghz to 3.8Ghz. I plan on doing the same with this new system. Just turning on the Turbo Mode. and it just goes to 5Ghz on one or two of the cores. Should I leave Multicore Enhancement enabled or disabled? for someone who isn't overclocking. What do you recommend? This board is overkill for my needs. But its nice to have all those features. Should you ever want to dabble on it. But I think that's the whole point of my new build. Overkill. Because I want something that does everything. Multicore enhancement is an easy way to get extra performance without having to overclock yourself. That being said it does usually go a bit high on the voltage for some boards and manufacturers so u would make sure you monitor your voltages if you do decide to enable the feature. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 8, 2019 59 minutes ago, TigerClaw said: Yeah. But the ambient temperatures in my room would not be good for Overclocking this day. on really hot days. Especially here in Florida. Temps right now is at 86F / 30C I live in Southern Utah just north of Las Vegas and Death Valley, it get's up to 117 degrees Fahrenheit here in the summer and room temps are pretty similar to yours even my previous Z370 Aorus Ultra Gaming which is significantly lower tier than the Master was fine and that is with an 8700k OC'd to 5ghz on all cores. I think you're stressing over nothing. With a 5.0ghz overclock there should be no issues with VRM cooling even with those ambients and a lower tier board. And if you really do have a PSU from 2012 and are upgrading to such highend components you should definitely upgrade to a new PSU. I wouldn't spend that much money on such a highend system then slap a 7 year old powersupply into it. If you have the budget to buy the parts you are, definitely upgrade that PSU too. Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z690 Aorus Elite AX DDR4 | GPU - ASUS TUF Gaming OC RTX 4090 | RAM - Corsair Vengeance Pro RGB 64GB 3600mhz | AIO - H150i Pro XT | PSU - Corsair RM1000X | Case - Phanteks P500A Digital - White | Storage - Samsung 970 Pro M.2 NVME SSD 512GB / Sabrent Rocket 1TB Nvme / Samsung 860 Evo Pro 500GB / Samsung 970 EVO Plus 2tb Nvme / Samsung 870 QVO 4TB | TV Streaming PC: Intel Nuc CPU - i7 8th Gen | RAM - 16GB DDR4 2666mhz | Storage - 256GB WD Black M.2 NVME SSD | Phone: Samsung Galaxy Z Fold 4 - Phantom Black 512GB | Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 8, 2019 Author 26 minutes ago, SpookyCitrus said: I live in Southern Utah just north of Las Vegas and Death Valley, it get's up to 117 degrees Fahrenheit here in the summer and room temps are pretty similar to yours even my previous Z370 Aorus Ultra Gaming which is significantly lower tier than the Master was fine and that is with an 8700k OC'd to 5ghz on all cores. I think you're stressing over nothing. With a 5.0ghz overclock there should be no issues with VRM cooling even with those ambients and a lower tier board. And if you really do have a PSU from 2012 and are upgrading to such highend components you should definitely upgrade to a new PSU. I wouldn't spend that much money on such a highend system then slap a 7 year old powersupply into it. If you have the budget to buy the parts you are, definitely upgrade that PSU too. Yeah. Maybe I should upgrade the PSU to a newer one. Would 850w still be fine? CPU: I9-9900k CPU Cooler: Noctua NH-D15 Memory: 32GB Corsair Vengeance LPX 3200mhz Dual Channel Motherboard: Gigabyte Z390 Aorus Master Soundcard: Sound BlasterX AE-7 Capture Card: Elgato Game Capture HD60 Pro Graphics Card: Gigabyte RTX 3080 Ti Boot Drive: Samsung 980 Pro NVME 1TB SSD Storage Drives: WD BLACK SN750 NVME 1TB SSD WD Blue 1TB SSD, Samsung 850 Pro 512GB SSD, 2 WD Blue 500GB SSDs Blu-Ray Drive: Pioneer BDR-2207 Power Supply: Seasonic PRIME 850 Platinum SSR-850PD 850W 80+ Platinum Case: Cooler Master HAF X OS: Windows 10 Pro Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 8, 2019 Just now, TigerClaw said: Yeah. Maybe I should upgrade the PSU to a newer one. Would 850w still be fine? 750W is fine, for your MB etc Pick something from Tier A+ or S. i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium. i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W. i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
