What Power Supply should I use?
Denyl
Hello,
I have an Dell Optiplex 7010 with an i5 3470 CPU, GTX 1050 and 12 GB RAM. My power supply is an Dell 0FC1NX L275EM-00 275W FC1NX as this one. https://www.youtube.com/watch?v=fYWf-oQXG-o
I found a PSU today on an older PC and I was thinking if I should replace it with mine.
It is an KCAS 500W .
I just want to know if it is better, I don't plan to buy something else.
@NunoLava1998 mentioned in your other thread that KCAS was no good.
In general, don't "upgrade" your power supply unless it's to something decent, and only if you actually need to.
Primary PC:
I see! I'm short on money and I was thinking that even if it a little bit better I should use it. But if you say the brand is bad I will stick with mine.
saving up extra money for a power supply is always a good idea, a good power supply is a good investment, especially for a system you don't want to lose.
Primary PC:
The "better" PSU is worse than your current one.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
Buy someting else.
Delta PSU are fine.
There is no reason to replace it with a low quality thing.
In general the PSU of decent OEM Systems are lower mid range. Something like be quiet System Power 9, Pure Power 10/11, Corsair CX (White Label), Cooler Master Master Watt, that is the bare minimum to replace the PSU with.
"Hell is full of good meanings, but Heaven is full of good works"
Sorry, correction: LiteON
And the PSU is 80plus GOLD Certified.
So my last post is incorrect. The PSU is even better than that...
A better one would be something like Bitfenix Formula for example.
