Please talk me out of cutting a hole in my laptop
thacko
I didn't think this belonged in one of the troubleshooting forums, because I don't actually have any problems... yet.
So I use an external GPU with my laptop - long story short, when I want to play something, I connect an external PCI-E mount to my laptop's internal M.2 port (where the WiFi card usually goes, there's a picture of the port in IMG_1122). Here's the thing: to do this, I need to flip my laptop upside down and close it to access the port, requiring me to use a second, old monitor. This means that while it works, it does require some sacrifices in usability and general display quality. However, I recently thought of something. What if I cut a hole in the bottom of my laptop to run the M.2 cable through (the attached IMG_1121 has a rectangle drawn in the location of the cut)? I'm sure the plastic can't be that hard - what's stopping me from just taking a pocket knife and sawing a hole through it? The way I see it, there are a couple of things I need to consider:
  • The hole needs to be sealed when I'm not using the eGPU. That's easy, I can just tape a dust filter over it.
  • I need to avoid trapping the cable when it's connected. This can be done by just propping up the laptop on some books.
  • I have to be sure I won't damage the components of the laptop. I feel like this is a good time to state that I'd remove the laptop's casing before cutting into it.
However, I'm worried that there's something I'm forgetting. I use this laptop more than I sleep; and if I messed it up, I'd be... disappointed. Do you see any potential downsides?
Most likely the pocket knife itself...
Looks fine. Don't worry about it. Enjoy your first mod. You seem very reasonable and have definitely overthought this.
I once gave Luke and Linus pizza.
Proud member of the ITX club.
**SCRAPYARD WARS!!!!**
#BringBackLuke
Alright, I've been sufficiently egged on. I'll do it now and let you all know how it goes.
Quick update: there seems go be a metal layer inside the casing. This might take a while to cut.
So it worked, in the sense that my laptop now has a taped-over hole and the whole thing still functions. However, I forgot two things:
  1. I need a way to ensure that the M.2 cable doesn't slip out of the port while I'm reattaching the casing. At the moment, it keeps slipping out before I turn the laptop on. (As I type this, I'm remembering that I could have just used the screw built into it to secure it...)
  2. I've just destroyed the resale value of the computer by putting a stonking great hole in it.
Yeah, nobody will probably buy that now, but hey you just modded a laptop...
Thats pretty cool ?
I got a ps5 and a pc pretty ballin
gun.exe
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
I... thought this was going to be a much different topic.
Thankfully, it's not what I thought it was. ?
