Best air cooler for i9 9900k
webguy
Hi.  I am building a gaming pc and would like some recommendations on a really good air cooler for it.  I will be playing mainly competitive fps games like apex legends and pubg and will likely be streaming from the same pc I game on.  I am planning to get a large case to have plenty of room for parts as I have the space I need for a big tower.  My gaming sessions may be 12+ hours at a time so I want a really good cooling system in place.  I am planning to get the i9 9900k and a 3 fan asus rog strix 2080 gpu.  I will likely be playing at 1440p 165hz.
I do not want the cheapest option but instead want performance and cooling to be the priority.  I had been thinking about doing an aio but after reading about leaks I think I want to go with an air cooler.  What is the best air cooler for the i9 9900k given that it will be used for long periods of time and I do not want heat to be a problem.  I will be playing and streaming and running more tasks on the computer so it will likely be pretty heavy use.
Thanks!
best aircooler you will find is the Noctua nh-d15
id also recommend waiting for Zen 2 to drop before spending all of your money on a 9900k CPU. its a bad time to go all out on a CPU
Agree with both of the above with the edge going to the Noctua for their customer service and 6 year warranty.
Thanks!
If you are willing to do basic modding, get a server cooler or heatsink and add fans.
NH D15
16 minutes ago, LukeSavenije said:
two options: nhd15, dark rock pro 4
no other ones needed
As said above, NH-D15 if you're okay with the terrible colour scheme :P
Dark Rock Pro 4 if you want something prettier looking
Both will do for the i9.
Personal Desktop":
Luna, the temporary Desktop:
I'm saying this in name of @GoldenLag
it's the colour of performance
LOL yup it shure is.  lol
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
You got that backwards, my friend. Noctua makes the prettiest coolers.
Thank you everyone for the information.  It looks like I will likely try the NH-D15.  Why did they make the blades brown though?  I mean why would they think that was a good idea?
rip lgm rt lol
Noctua NH-D15S checking in! Got the S model in case I change my configuration and need to utilize tall ram. Also have the black.chromax fans and heatsink covers (still have brown case fans though).
Forgive me El Guapo. I know that I, Jefe, do not have your superior intellect and education...
well, is it something they can set their selves apart with?
there's your answer
there's your answer
I personally care more about performance than what it looks like but it would have been a good move financially for them I think if they offered an upgrade for a few dollars more for different color fan blades.  I would pay a few dollars more for blue etc.
I'm afraid Chromax (noctuas black and for example blue fans) comes at a heavier cost...
tho the dark rock pro 4 should fit in with the colors
