can you swap out a screwed in glass side panel for a door?
Solved by TVwazhere,
On 3/2/2019 at 9:13 AM, gboucher said:I have a Corsair Carbide case with hex screws to hold the glass side panel in place...
I'm assuming this is the 275R based onm the description. The Hex mount is personally my biggest complaint about the overall case.
You could order 460 Screws as suggested in this thread:
