Strange water cooling config... thoughts?
4 hours ago, Steve1978 said:Interesting what you say about pump speeds, I can see how it would help having multiple pumps at the same speeds but IF you had differing speeds wouldn’t the additional pumps just help push the water round or would they actually slow the water down?
Im regurgitating what Ive been told by those much more wide and learned on custom loops than I after asking the same questions (and I have 2 pumps I wanted to use). By definition however this is what happens when to much flow is allowed through a pump:
Air entrainment occurs when air is allowed to enter the pump on the suction side and expands as it enters the impeller eye. This can often reduce the flow of the pump and cause vibration from disrupting the laminar flow stream through the pump. Air entrainment can cause similar damage to bearings and seals.
I also spoke with someone who used AIO block/pumps in tandem with loop pumps and he said don't do this unless you can control the speeds to be the same RPM, if you cant then gut the AIO pump/block to its just a block as they are quality blocks.
