CPU overheat when AIO is placed on rear fan slot.
Dyepoy
Go to solution Solved by Dedayog,
Just now, Dyepoy said:
I will follow that. Last question according to my fans on the rad. Should I place the 2 fans on the opposite direction? front intake, rear exhaust or should I go both intake/exhaust? Sorry for this noob questions. This is my first AIO.
Just like we said above... leave the AIO in front as in intake fan (pulls air from outside and brings it into the case), and add a rear one to exhaust (pulls air from in case to push it out the back)..
You want the case to act like a wind tunnel or hair dryer, etc.
Hi, I'm just wondering why my AIO (Corsair H80i V2) is overheating when placed like this:51048605_476599729539111_7697672247405707264_n.thumb.jpg.c7ea76914633ca668ec62ae9d78a652c.jpg
And its temps are normal when placed like this:
52460270_2138013682931436_1531921453304250368_n.thumb.jpg.e54f04e37bd1c1e60a0835c1814ba43f.jpg
I've seen some websites that are placing that same AIO on the rear and not having any temperature problems.
PS: Sorry for the crappy cable management.
Thanks! :)
Rig: CPU: Intel Core i7 7700 | Motherboard: Asus Maximus IX Code | RAM: G. Skill Trident Z 2x8Gb 3000Mhz RGB |
GPU: MSI GTX 1080Ti Gaming X | PSU: Seasonic PX650 | Case: Phanteks P400S |
Storage: Samsung 970 Evo (OS Drive) & Samsung PM981 (Game Drive)
Thanks! :)
Airflow.  In front, it's getting cool air from outside the case, and when in back it's having all the hot air from the case run thru it,
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
Thanks! :)
My best guess is your GPU is dumping a lot of heat since it's a downdraft cooler and then being drawn through the AIO limiting it's cooling capability. With it in the front it's getting the coldest possible air, you may want to add an extra exhaust fan to help promote flow through the case.
Would placing 2 fans on the front help? I don't have any case fans at the moment, just the fans in the rad. My side panel is also open (still not closing the case until my build is finished.
Leave the AIO in front, add another intake in front and add an exhaust fan for the back.
Or at the very last leave the AIO in front and add an exhaust fan in back.
Did the case not come with any fans at all?
OnePlus:
Other Tech:
I stress test the CPU to check for its temps. The GPU is running @ 40c since its only CPU intensive benchmark (prime95) and the heat is still rising up to 90-100c. Sadly my case doesn't have top fan slots. Just front. I can't put another fan on the bottom since my cables are there (non modular psu)
As suggested I'd leave it in the front and add a rear exhaust to help move the air through the case to make sure things don't get too toasty inside.
It does come with molex powered nzxt fans which I didn't use since I can't control its speed and only running at a constant speed. Maybe I'll get a set of fans next week. I didn't know that case fans can really affect the temperature of the computer that much.
Do me a favor, turn on your ceiling fan tonight in your room, then come back  and edit that statement :)
OnePlus:
Other Tech:
OnePlus:
Other Tech:
Hahaha. I'm sorry for my ignorance.
I would do front intake, now I look closer it's actually going exhaust out the front, turning both the fans around so it's push pull as intake should help quite a lot. You want the fans on the rad to both be in the same direction or it will just fight each other yielding no cooling or airflow.
I'll do that as soon as I get my new set of fans. Thanks!
The fan on the picture that's going outside is actually unplugged. Only the front is plugged which the air is going inside the case. image.png.eeb421f847886c5ac7c9b44e02a5edf1.png
That's crappy drawing of my case. The red are the fans and the yellow is the rad. All the fans in the front are intake and the rear fan will become the exhaust. Now I'll just have to figure out how to hide the wires from the pump to make it look nicer. Thank you for helping me out. :)
Glad to help.  You should have noticeably lower temps all  around with that new fan config you drew. Or is it you've drawn?  hmm.
OnePlus:
Other Tech:
That looks good to me, if you can try tucking the cables around the cooler and if they are long enough run them up and around back behind the motherboard tray.
Technically, they work differently. A ceiling fan is creating a wind chill effect by cycling air in the room, but the air enters the fan at room temperature and leaves it into a room temperature environment. There's no change in air temperature associated with it. A case fan is actively pulling room temperature air into the case and displacing the hot air or pulling hot air out of the case and dumping it into the room temperature environment around it. If you want the same effect in your bedroom, cut a hole in your roof and use a 747's engine as your attic fan.
Aerocool DS are the best fans you've never tried.
True but having a person experience the wind chill effect is just the easiest way to pseudo-demonstrate.
A better example would be to open windows on opposite sides of the house to get an airflow path of cool air in the winter, probably should have gone with that.
OnePlus:
Other Tech:
I prefer the JT9D attic fan, tbqh.
