Monitor recommendations
Pove
I’m trying to achieve a monitor layabout exactly like this has anyone got any recommendations for monitors that don’t break the bank. Thanks :)
What is your total budget?
What monitors do you already have?
What is your pc hardware? Alternatively, what refresh rate and resolution do you want your main monitor to be?
Do you want your main monitor to be the top or bottom one in the center?
My PC Specs: (expand to view)
Main Gaming Machine
CPU:  Intel Core i7-14700K
CPU Cooler: Deepcool LT720
Motherboard: MSI PRO Z790-P WIFI
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000
Storage 1: Samsung 990 Pro 2 TB
Storage 2: Crucial P3 Plus 4 TB
Video Card: EVGA XC3 ULTRA GAMING GeForce RTX 3080 10GB
Power Supply: Corsair RM850 850W
Case: Corsair 4000D Airflow
Case Fan 120mm: Noctua F12 PWM 54.97 CFM 120 mm (x1)
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x2)
Monitor Main: MSI G274QPF-QD 27.0" 2560 x 1440 170 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
My budget is around 1k and I’d like my monitors to be preferably 1440p and at least 165hz. I would like to alternate between the ultra wide and the bottom one 🙂
Tbh you'd just be better off with a 42" or 48" TV-sized monitor and then use fancy zones or other zoning tools to get the app layout you want. There's not way you'd fit 4 decent monitors into that kind of budget.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
