HELP NEEDED - How To - lock-in wifi settings "before & after boot"
Solved by Thomas4,
From Ubuntu
1. Open a Terminal and Type: su it should ask for your root password, in most cases this is the same as your user password, unless on a shared device with multiple users.
If you don't get the requestor, type sudo As I've never tried Ubuntu, I'm not sure which command works.
The prompt will change
2. Enter nano /etc/network/interfaces and amend your file to read:
auto lo
iface lo inet loopback
auto wlan0
iface wlan0 inet dhcp
wireless-ssid SSID_Name IN YOUR CASE IT'S v5
wireless-key XXXXX
Then save and exit.
Next I suggest fully shutting down and restart as opposed to simply rebooting.
