So I have a Superclocked EVGA GeForce GTX 970 ACX 2.0 Graphics Card paired with a Ryzen 5 2600X OC'ed to 4.1Ghz and DDR4 3000 16GB RAM OC'ed to 3133mhz and want to overclock it so there is better performance in gaming but video rendering too and less "bottleneck". If I overclock it with let's say a 150-200mhz+ core clock and 350-400+ memory clock while having to increase voltage and power limit and temperature limit, will it reduce life significantly?
https://linustechtips.com/topic/1020702-will-overclocking-gpu-reduce-lifespan/
significantly, no.
Desktop benching:
Voltage is what kills. What's your Vcore?
Primary PC:
PSU tier list
How many watts do I need?
and heat :)
HEDT: i9 10980XE @ 4.9 gHz, 64GB @ 3600mHz CL14 G.Skill Trident-Z DDR4, 2x Nvidia Titan RTX NVLink SLI, Corsair AX1600i, Samsung 960 Pro 2TB OS/apps, Samsung 850 EVO 4TB media, LG 38GL950G-B monitor, Drop CTRL keyboard, Decus Respec mouse
Laptop: Razer Blade Pro 2019 9750H model, 32GB @ 3200mHz CL18 G.Skill Ripjaws DDR4, 2x Samsung 960 Pro 1TB RAID0, repasted with Thermal Grizzly Kryonaut
Gaming Rig: i9 9900ks @ 5.2ghz, 32GB @ 4000mHz CL17 G.Skill Trident-Z DDR4, EVGA RTX 2080 Ti Kingpin, Corsair HX1200, Samsung 970 EVO Plus 2TB, Asus PG348Q monitor, Corsair K70 LUX RGB keyboard, Corsair Ironclaw mouse
HTPC: i7 7700 (delidded + LM), 16GB @ 2666mHz CL15 Corsair Vengeance LPX DDR4, MSI Geforce GTX 1070 Gaming X, Corsair SFX 600, Samsung 850 Pro 512gb, Samsung Q55R TV, Filco Majestouch Convertible 2 TKL keyboard, Logitech G403 wireless mouse
Heat kills, as does poor quality components.
An overclock itself won’t do anything.
3 hours ago, AYDANN6ix9ine said:
iirc 970s are locked to very low voltages around 1.3v, so it won't be a problem, just watch temps below 80-83 prefered, but technically oc'd parts should die faster than non-oc'd parts on paper.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
No, that the completely opposite of the truth.
Temperature is what causes damage, not voltage.
Voltage doesnt kill anything. Its the current (amps) what kills a device, component or a human being.
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
Ah ok I'll just set my Vcore to 5 volts then, I'm sure it's fine.
Really though, semiconductors wear out due to the kinetic energy of electrons degrading the internal transistors, even if you kept a CPU at 30 degrees it wouldn't last forever. A copious amount of voltage at a safe temperature will cause problems and a safe voltage at a copious temperature will cause problems. It's not the opposite of the truth, it's only half of what you need to look out for.
And yes, I know what popcorning is.
Primary PC:
PSU tier list
Alright, if you wanna get super technical about it it's actually Coulombs, which are then composed of electrons, because one Amp is one Coulomb per second. Also, with 0 voltage, any amount of current has no potential and therefore can't move, so you need voltage and current to kill people
Still though, there's no setting in the BIOS for "current control" so when someone tweaks voltage to change wattage then that's how they overload a CPU.
Primary PC:
PSU tier list
Yes the one without the other is nothing.  Correct.
should of left my explain part in my comment, would of saved you from typing it out. ;)
Might as well take some fun in nitpicking if I can.
Primary PC:
PSU tier list
in the context of this conversation, voltage will indeed kill things. No need to purposely mislead someone who is trying to learn :)
And not even in the context of this conversation, voltage is a form of potential, which leads to kinetic energy, and that's what degrades things over time.
Primary PC:
PSU tier list
yep - just trying to keep things simple for the OP too, since the end result of our answer should be something to the effect of "running your PC parts with too much voltage is an unwise idea", technical specifics aside.
The only thing overclocking would do to reduce lifespan of a component is the overclock producing higher heat. Nothing more, nothing less. However if you can keep the average temperature of the GPU the same as what it was expected to run at, there won't be a significant difference in life span.
If you set vcore to 5V it will only damage the transistors because of heat.
If you kept it at 30C it WOULD last just as long as a regular CPU at regular voltages.
The problem is you CAN'T keep it at 30C because you can't cool the transistors directly, only the top layer of silicon of the CPU.
The distance between the area of cooling and the transistor is too far, causing a huge temperature gradient.
Even though the surface of the CPU might be at -272C the transistors would be far above 30C and would die instantly.
Again, it is the temperature that causes the damage, not the voltage.
If you have a transistor that isn't buried under layers of silicon you can do 7V+ and even more if you cool it actively.
It's all about how how the actual transistor gets.
The cards are locked from using dangerous voltages.  With the amount of control you have it will still outlive its usefulness.
AMD 7950x3D / Gigabyte Aurous Master X670E/ 64GB @ 6000c30 / 3 x 4TB Samsung 990 Pro / 44TB Synology 1522+ / MSI Gaming Trio 4090 / EVGA G6 1000w /Thermaltake View71 / LG C1 48in OLED + MSI 321URX - Moved back to air cooling Phantom Spirit 120 SE.  Server (PLEX) - 155H NUC 64GB  and 60GB Optane drive/ Server (AI) 64GB M4 Max Mac Studio
In the context of this conversation, it is heat, caused by increasing the voltage, which can kill things.
The temperature also depends on OP's cooling method, not the voltage alone.
If he has a good cooler on it, he can easily increase his voltage by a few hundred millivolts and the temperatures will still be fine, and his CPU/GPU lifespan will not be reduced.
No need to mislead people and tell them that more voltage will kill their CPU/GPU, when it will not.
More heat will.
That is why you need to monitor temperatures under load when overclocking, and buy a new cooler if necessary.
In fact, nvidia GPUs are limited at a certain max power and offset, so you can give them all the voltage and power you want and it will be limited to safe amounts anyway.
Actually Hardcore Overclocking describes voltage and heat damage as two separate characteristics
Steve burke covered this, and it's a well understood phenomena
https://www.edn.com/electronics-news/4382044/What-Causes-Semiconductor-Devices-to-Fail-
different types of failure
http://www.circuitstoday.com/pn-junction-breakdown-characteristics
junction breakdown
edit:
check out this video at 9:30 in
Quote
either indirectly from too much heat, or directly from just being too much voltage
Primary PC:
PSU tier list
More heat will.
You just reiterated my point, so thank you.
For someone new to this type of scene, telling them not to worry about voltage because "only heat kills" is a terrible idea.
Too much voltage will indeed kill, both directly and indirectly as you will learn in any basic electronics class.
junction breakdown
1) If you read your first link, which I assume you're talking about electrical overstress, everything described there about derating components and electrical stress has to do with heat. The damage is caused by heat (except in the rare case where it arcs and shorts, which is caused by ESD)
All the other stuff has to do with heat.
All those transistors and diodes have a resistance that causes an increase in current when you add voltage. This in turn heats up the components and traces and everything else.
2) says the same thing I've been telling you repeatedly.
It allows lots of current through and causes damage.
Guess why? Because heat.
Saying it all like this guy is gonna do much more than move the slider up on afterburner.
Which in turn won’t do anything. Unless the card is supposed to last 10 years and dies in 8. I’m sure he will be just fine.
