37 minutes ago, ReemX44 said:
Would a "ZOTAC Gaming GeForce RTX 2080 Amp Extreme" fit inside a "CORSAIR Carbide SPEC-Omega RGB"
i dont want to take risks about this would it?
If all else fails, beat it to fit, paint it to match ?
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1009837-help/#findComment-12094115
Corsair Spec Omega
Maximum GPU Length - 370mm
Zotac AMP 2080
Card Length - 324mm x 136mm x 59mm (12.75in x 5.35in x 2.32in)
You got 50mm (2") of room, so you're fine. Might be tight if you try to front mount a liquid cooler which is usually 52mm thick.
https://linustechtips.com/topic/1009837-help/#findComment-12094202
On 12/18/2018 at 3:57 PM, TVwazhere said:
Corsair Spec Omega
Zotac AMP 2080
Will probably mount it on top thank you all!
https://linustechtips.com/topic/1009837-help/#findComment-12107700
