Are laptop cooling pads worth it?
YellowJersey
Just like the title says, is a laptop cooling pad a sensible purchase? Or is it gimmicky? I've got a 15 inch laptop that I mostly use as a desk top and was wondering if a cooling pad would make any noticeable difference.
 Anyone have experience with these things? Yay or nay?
System Specs: Second-class potato, slightly mouldy
If your laptop is having thermal problems, just undervolt or maybe do a repaste (which is still cheaper than buying a cooling pad)
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
depends on how the laptop's cooling system is set up I imagine... like on a Razer Blade it would probably help since it pulls in air from the bottom and exhausts it out the back but not all laptops are designed that way.
HEDT: i9 10980XE @ 4.9 gHz, 64GB @ 3600mHz CL14 G.Skill Trident-Z DDR4, 2x Nvidia Titan RTX NVLink SLI, Corsair AX1600i, Samsung 960 Pro 2TB OS/apps, Samsung 850 EVO 4TB media, LG 38GL950G-B monitor, Drop CTRL keyboard, Decus Respec mouse
Laptop: Razer Blade Pro 2019 9750H model, 32GB @ 3200mHz CL18 G.Skill Ripjaws DDR4, 2x Samsung 960 Pro 1TB RAID0, repasted with Thermal Grizzly Kryonaut
Gaming Rig: i9 9900ks @ 5.2ghz, 32GB @ 4000mHz CL17 G.Skill Trident-Z DDR4, EVGA RTX 2080 Ti Kingpin, Corsair HX1200, Samsung 970 EVO Plus 2TB, Asus PG348Q monitor, Corsair K70 LUX RGB keyboard, Corsair Ironclaw mouse
HTPC: i7 7700 (delidded + LM), 16GB @ 2666mHz CL15 Corsair Vengeance LPX DDR4, MSI Geforce GTX 1070 Gaming X, Corsair SFX 600, Samsung 850 Pro 512gb, Samsung Q55R TV, Filco Majestouch Convertible 2 TKL keyboard, Logitech G403 wireless mouse
I used to use them back when I gamed on a macbook pro. It helped significantly since that specific computer used the bottom of the "case" as a massive heatsink. It was also one of the powered kind of laptop cooling "pad" (more like a stand). So it plugged into the USB port and had two 80 mm fans that blew air onto the bottom of the laptop. I definitely noticed differences back then, don't exactly remember how much though.
If your laptop air intake is on the side, I doubt a cooling "pad" would help.
Honestly I think most of the pads are to help people who use a laptop on a soft surface (like the bed).
If your laptop has intakes on the bottom, a cooling pad could help, in theory. But you could also try propping the laptop up on something, this would be easier to do if you use an external keyboard or would be willing to switch to one. Its pretty easy to build a little stand to lift it up for more airflow (old books, some unused and small cardboard boxes, some small and unused wood planks, etc).
Side intake laptops wouldn't benefit from either.
A passive laptop would be better off with a cooling pad
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
simple ans: not worth it.
if you notice the table become warm / hot then
just raise laptop by any means , (i use pocket tissue) no addition fans need
if the laptop still overheats, then it has really poor design
The laptop in question is a Lenovo T530, which I think has its primary intake at the back? I already have it propped up using some DVD cases, so there's some pretty significant clearance under the machine. I have noticed that some spots on the bottom can get pretty warm, though.
 I'll try repasting first and see what that does.
Make sure you choose the correct paste
http://forum.notebookreview.com/threads/which-thermal-paste-to-buy-and-apply-traditional-and-liquid-metal.806840/
Desktop specs:
