I have multiple numbers in one column (I'm counting my grades) and I have their sum in a column next to it. So I need an average number of that column, so it's sum divided by the number of numbers (grades) [ S/n , where S is sum and n count of numbers I have] I have in that one column.
What formula do I use? AVERAGE doesn't work, because it doesn't count the numbers in that one column where I have multiple numbers
Hope you understand ( English is not my native language )
https://linustechtips.com/topic/993974-excel-help/
average = SUM() / COUNT()
https://linustechtips.com/topic/993974-excel-help/#findComment-11957446
Nope, shows a #DIV/0! Error
This is the formula I've used to calculate the SUM of that one column, since SUM function didn't count every number in that column:
=SUM(IF(ISERR(VALUE(MID(B12,ROW($B$1:OFFSET($B$1,LEN(B12)-1,0)),1))),0,VALUE(MID(B12,ROW($B$1:OFFSET($B$1,LEN(B12)-1,0)),1))))
https://linustechtips.com/topic/993974-excel-help/#findComment-11957456
If the above didn't work, could you post a screenshot of your table?
Current Build:
CPU: AMD Ryzen 5 2600 // Mobo: Ryzen AM4 B350 GAMING PLUS ATX // RAM: 16GB Corsair Vengeance LPX DDR4 3000MHz // GPU: Gigabyte AMD Radeon RX 580 Gaming 8GB // SSD: Kingston A400 120GB // HDD: 3 x WD Blue 1TB // PSUCorsair 650M // Case: Corsair 450D // Monitor: LG Ultrawide 29" IPS
Plex Server:
CPU: AMD FX 8350 Black Edition // Mobo: Gigabyte - GA-78LMT-USB3 R2 Micro ATX // RAM: 16GB Corsair Vengeance DDR3 1600 MHz // GPU: GeForce GTX 670 // HDD: Seagate BarraCuda 2TB // PSU: Kolink Core Series 500W 80 Plus Certified // Case: AVP Viper Mini Tower
Other:
PS4 Pro // PS3 // Nintendo Switch (Pokemon edition) // Nintendo 3DS // Xbox 360 // iPhone 8 Plus // Macbook Retina 2013
https://linustechtips.com/topic/993974-excel-help/#findComment-11957458
That's not a column that's a row...
https://linustechtips.com/topic/993974-excel-help/#findComment-11957577
6 minutes ago, Mrshan said:
oh yes... sry my bad
but I want to use this "3 4" column to divide with 7 hahah
Why can't you put the different values into individual cells?
That's how spreadsheets are meant to be used.
https://linustechtips.com/topic/993974-excel-help/#findComment-11957798
I'm too lazy to change it now, even if it's easy af
I assume I'll do that, have individual cells, since I can't find a solution
https://linustechtips.com/topic/993974-excel-help/#findComment-11957801
You'll have to. The way it is now, Excel sees those cells as text/general. You can't have any other symbols in number cell but numbers and comma/dot (which ever you would use as decimal separator). And + or - at start to symbol positive and negative values. Tip regarding that, if you want to show + mark before number, have ' at start of it. Works also if you need to write out formulas. But Excel will then use that cell as text/general.
You can have header cell merged from all column headers you need for different grades.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/993974-excel-help/#findComment-11961821
(LEN(TRIM(A1))-LEN(SUBSTITUTE(TRIM(A1);" ";"")))+1
This formula returns number of grades in your case.
Replace A1 with cell where you have your grades.
And you still can use it the way you like (in single cell with spaces).
Don't worry about double spaces or spaces at the beginning or the end - they do not count.
Excel is really powerful program and if something can't be done using formula, there is always VBA.
https://linustechtips.com/topic/993974-excel-help/#findComment-11962402
TY for that but I ended up making a cell by cell Worksheet, where every grade had it's cell
https://linustechtips.com/topic/993974-excel-help/#findComment-11964736
