what is this port on the rgb led controller?
wow just wow....
There's even a heading at the bottem of the product page you just linked that says
EXTRA INFORMATIE
and under it is
if you open it it reads
Specifications & Packing Information
Product Name MasterFan Pro 120 Air Flow RGB 3 in 1 with RGB LED Controller Product Number MFY-F2DC-113PC-R1 Fan Profile Red, Blue, RGB Dimensions 120 x 120 x 25 mm(4.7 x 4.7 x 1 inch) Fan Speed 650-1,100 RPM ± 10% Air Flow 48.8 CFM ± 10% Air Pressure 0.88 mmH2O ± 10% Noise Level 6 – 20 dBA MTTF 490,000 Hours L-10 Life 70,000 Hours Fan Connector 4–Pin Rated Voltage 12 VDC Rated Current 0.17 A Safety Current 0.4 A Power Consumption 3.84 W Weight 162 g RGB LED Controller Dimensions 90 x 53 x 14mm (3.54x2.08x0.55 inch) LED Connector 4 Ports Interface 9-Pin USB 2.0 Connectors Power Connector SATA Power Software Yes Accessories 450mm RGB LED Extension Cable x 4 600mm USB 9 Pin Extension Cablex1 Metal Screw x 12 Warranty 5 Years
Hope this helps.
