APU vs CPU - Difference?
Go to solution Solved by Brooksie359,
2 minutes ago, Hi P said:
I see, so without overclocking a 2200g is a better option? can it use a dedicated graphics card without problems?
Yeah the 2200g will preform better out of the box. It will work just as well with a dedicated gpu as any other cpu so you should have no issues.
If you have two identical systems, with a dedicated graphics card on both of them:
- What's the difference between a system with a CPU and a system with an APU?
This question came to my mind when I saw the Ryzen 3 1200 being a bit pricier than the Ryzen 3 2200g, since both have identical specs but the later has integrated graphics.
Thank you
https://linustechtips.com/topic/987079-apu-vs-cpu-difference/
Thank you
APU - accelerated processing unity
CPU - Central processing unit
apu has integrated gpu
cpu doesnt
✧・゚: *✧・゚:*  Quote for a reply  *:・゚✧*:・゚✧
✧・゚: *✧・゚:*   Ask for discord   *:・゚✧*:・゚✧
https://linustechtips.com/topic/987079-apu-vs-cpu-difference/#findComment-11892741
Because APU has iGPU inside, TDP gets shared between GPU and CPU parts, which may result in lower clock vs. no iGPU unit.
CPU : Core i7 6950X @ 4.26 GHz + Hydronaut + TRVX + 2x Delta 38mm PWM
MB : Gigabyte X99 SOC (BIOS F23c)
RAM : 4x Patriot Viper Steel 4000MHz CL16 @ 3042MHz CL12.12.12.24 CR2T @1.48V.
GPU : Titan Xp Collector's Edition (Empire)
M.2/HDD : Samsung SM961 256GB (NVMe/OS) + + 3x HGST Ultrastar 7K6000 6TB
DAC : Motu M4 + Audio Technica ATH-A900Z
PSU: Seasonic X-760 || CASE : Fractal Meshify 2 XL || OS : Win 10 Pro x64
https://linustechtips.com/topic/987079-apu-vs-cpu-difference/#findComment-11892747
APU is a marketing term from AMD.  It's specifically referring to CPU and GPU on same die.
A CPU shouldn't have a GPU integrated, but it's become an umbrella term now.  Like my 8700K CPU is running well.  But it has graphics too, so...
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/987079-apu-vs-cpu-difference/#findComment-11892751
cpu doesnt
Isn't the i5 8250u a CPU?
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/987079-apu-vs-cpu-difference/#findComment-11892752
Thank you
The 2200g can run off it's integrated graphics if you need to like if there is an issue with your gpu while the 1200 cannot.
https://linustechtips.com/topic/987079-apu-vs-cpu-difference/#findComment-11892753
APU is the name AMD gives to it's CPUs that have an iGPU.
Intel just calls all their CPUs a "CPU" even if it comes with integrated graphics.
https://linustechtips.com/topic/987079-apu-vs-cpu-difference/#findComment-11892762
I was looking at the specs between the 1200 and the 2200g, apparently the 2200g has higher clocks, though the 1200 is still a bit pricer, why?
https://linustechtips.com/topic/987079-apu-vs-cpu-difference/#findComment-11892768
But then why is the 1200 pricer? what makes it better than the 2200g?
The one upside of the 1200 is it tends to be able to overclock slightly higher due to it being soldered. Honestly I think the 2200g is the way to go because it's priced better and it still overcloks well.
https://linustechtips.com/topic/987079-apu-vs-cpu-difference/#findComment-11892769
As @jstudrawa said, APU is a marketing term from AMD. Otherwise if you went and said it was a processor package that includes a CPU side and a GPU side, then Intel's mainstream processors since Sandy Bridge are all technically APUs.
Though the original idea for where the "accelerated" for "Accelerated Processing Unit" came from was that AMD was pushing for adoption of Heterogeneous System Architecture or HSA (https://en.wikipedia.org/wiki/Heterogeneous_System_Architecture) The basic idea was that traditionally, the CPU and GPU had portions of RAM that neither one could access without going through a bunch of hoops. HSA allows the CPU and GPU to access the same memory locations, letting software that could use the computing power of the GPU do so easily: just drop the data into the memory region and the GPU can go to work while the CPU can pick it up as needed. I can't find any benchmarks, but I do recall seeing some where HSA really boosted things like video encoding.
https://linustechtips.com/topic/987079-apu-vs-cpu-difference/#findComment-11892772
If you're buying based on prices you're doing it wrong.
Being pricey doesn't mean any thing performance wise.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/987079-apu-vs-cpu-difference/#findComment-11892793
because AMD wants moneys, and then2200g was made for budget gaming
https://linustechtips.com/topic/987079-apu-vs-cpu-difference/#findComment-11892797
https://linustechtips.com/topic/987079-apu-vs-cpu-difference/#findComment-11892798
https://linustechtips.com/topic/987079-apu-vs-cpu-difference/#findComment-11892811
