Is a 240mm radiator enough for a gpu and cpu?
Solved by DailyProcrastinator,
4 minutes ago, littlepigboy5 said:Do you think the added 140mm rad would help?
Yeah, I think it would make a big difference. Why don't you try with the 240mm rad first then add the 140mm rad if your temps are too high?
Featured Topics
Worstcaster ·
Posted in Peripherals1 -
3
5
davidholzapfel09 ·
Posted in New Builds and Planning4 -
4
11
Gianluca95 ·
Posted in Graphics Cards1 -
6
8
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
