Intend to build suitcase pc, planned the innards, need input
saras
So yes, I've wanted to make a suitcase pc for aeons now. And since I've had a free evening I went about and tried to plan something.
Ended up with this:
post-4862-0-45812400-1388871228_thumb.jp
At the end. I'd end up with a roughly 54(perhaps longer if I need more space for the cables) x 35 x 15cm box. That I'd then fix into a suitcase.
I'd build the skeleton of the box out of 6mm thick acryllic(indicated by diagonal lines)(horizontal lines indicate free space). I'd put airways where it'd be in the way of the airflow. The motherboard and the GPU lead the I/O into the case, because I'd reroute it all, well the part's I'd need, to the top of the case individually.
So yeah, input?
looks cool i wanna see how it looks finished
| i5 4690K 4,4Ghz | Gtx 680 Msi twin frozr Oc edition | Kingston HyperX 2 x 4 Gb | Asus Z97-A | Seagate Barracuda 1 TB| Samsung 840 EVO SSD 120GB | Fractal Design Integra 750 W | All gently placed with great fright inside a Fractal Design Define R4 |
| ProJect Head Box S USB with Hifiman HE-400's plugged in | Check profile page for more Audio shizzle(dizzle) |
