I am collecting parts for my first custom loop.  I already ordered my fans and radiator...HWLabs 420GTX and 280GTX with 5 x Noctua NF-A14 PWM Chromax.  I decided I will be going with soft tubing for now.  I am looking for the very best soft tubing...also what size?  I am planning on clear liquid, if it maters.  I don't mind spending if the product is worth it.  I am also thinking EKWB EK-XRES 140 Revo D5 RGB PWM for pump, unless someone has a better suggestion.
i9-9900k @ 5.1GHz || EVGA 3080 ti FTW3 EK Cooled || EVGA z390 Dark || G.Skill TridentZ 32gb 4000MHz C16
 970 Pro 1tb || 860 Evo 2tb || BeQuiet Dark Base Pro 900 || EVGA P2 1200w || AOC Agon AG352UCG
Cooled by: Heatkiller || Hardware Labs || Bitspower || Noctua || EKWB
https://linustechtips.com/topic/975249-best-soft-tubing/
Black: EK ZMT
White: Mayhems UV White
Clear: Mayhems Ultra Clear
3/8 ID 5/8 OD or 1/2 ID 3/4 OD are the two best sizes.
Pick whichever you like best.
https://linustechtips.com/topic/975249-best-soft-tubing/#findComment-11783534
2 minutes ago, Enderman said:
Black: EK ZMT
Awesome.  Thanks!
Any suggestion for fittings?  I was just going to go with EK.
https://linustechtips.com/topic/975249-best-soft-tubing/#findComment-11783537
10 minutes ago, TahoeDust said:
Awesome.  Thanks!
Bitspower is more expensive but better.
EK fittings have leaked for quite a few people.
https://linustechtips.com/topic/975249-best-soft-tubing/#findComment-11783558
i use Alphacool 3/8 fittings. imo these are the best quality wise. i know that EK can leak in some cases, tough that is very rare. bitspower is kinda expensive.
if you are feeling lucky, you can also go for barrows, tough i can't vow for their quality.
https://linustechtips.com/topic/975249-best-soft-tubing/#findComment-11783560
I don't really mind spending the money.  If they were the same price, Bitspower or Alphacool?
https://linustechtips.com/topic/975249-best-soft-tubing/#findComment-11783566
Bitspower, tough imo they are not wirth their premium. quality is top-notch, tough so is alphacools for less money.
it's also a aesthetics thing. people tend to like Bitspower's looks more.
https://linustechtips.com/topic/975249-best-soft-tubing/#findComment-11783577
26 minutes ago, TahoeDust said:
Awesome.  Thanks!
my EK ones are great but if you dont mind spending money then get something from bitspower as they are top notch quality.
as mentioned Mayhems ultra clear is the best clear soft tube but it does have a very slight blue tone to it, but its not bad. easy to work with and looks great so far in Northern Bee :)
Builds:
https://linustechtips.com/topic/975249-best-soft-tubing/#findComment-11783602
Bitspower, every high end PC builder uses them, and with so many sold there is a large sample size out there.
The last time there was an issue with their fittings was 2012 or 2015 or something like that.
Ever since then, pretty much nobody has had any leaks that didn't involve user error.
https://linustechtips.com/topic/975249-best-soft-tubing/#findComment-11783618
Some other people have recommended Primochill Primoflex as well as Mayhem.  Said both were great, Primochill may be a little better, bur a little pricey-er.  Kind of like Bitspower vs Alphacool...
https://linustechtips.com/topic/975249-best-soft-tubing/#findComment-11783621
Bitspower it is.  Can't have this leaking on the 9900k/2080ti...yes I know both are overpriced and bad values.
https://linustechtips.com/topic/975249-best-soft-tubing/#findComment-11783632
But it's the best that exists, so technically the best value if you're going for top performance ;)
https://linustechtips.com/topic/975249-best-soft-tubing/#findComment-11783652
You are speaking my language.  I wish I could buy you a beer.
Right now I am looking at this...
o0ohfle.png?1
to go with what I already bought....
mgKnOt9.png?1
ZUUD0dO.png?1
https://linustechtips.com/topic/975249-best-soft-tubing/#findComment-11783674
Cool, seems like you did your research, got some of the best radiators :)
https://linustechtips.com/topic/975249-best-soft-tubing/#findComment-11783683
Do you think I will need any of the angled fittings?...or is there any advantages to using them instead of making bends with the tubing?
https://linustechtips.com/topic/975249-best-soft-tubing/#findComment-11783696
Just for looks or if you need to do a tight run, sometimes angles will make things easier.
https://linustechtips.com/topic/975249-best-soft-tubing/#findComment-11783703
I'm honestly not sure if I am going to "need" them or not.  I can not get my hands on the case I want yet...Phanteks Evolv X.  I will be going z390 Maximus Code, 9900k, and EVGA 2080 ti FTW3 (pre-ordered).  I just thought since I was ordering, I may want to pick up some of the angled fittings so I don't pay shipping twice, or get to a point where I need them to finish the assembly, and don't have them.
https://linustechtips.com/topic/975249-best-soft-tubing/#findComment-11783719
Deep in my soul I feel like I really want to be doing a hard tube setup.  The just look so sick.  I have a heat gun, I don't mind putting in the time.  Which is more leak prone?  Which would you do?  If I was to go hard, what tubing would you look at.  Sorry for all the questions and indecisiveness.
https://linustechtips.com/topic/975249-best-soft-tubing/#findComment-11783772
I'm sorry if I wasted any of your time @Enderman @Bananasplit_00 @RollinLower
I really thought I had talked myself into going soft, but I know the whole time know I will have wished I would have gone hard.  This is what I ended up ordering...
It is probably more fittings than I will need, but I don't like ordering twice...or a third, fourth, and fifth time.
Wish me luck.
https://linustechtips.com/topic/975249-best-soft-tubing/#findComment-11784204
When I was ordering fittings I didn't plan out my loop enough and had to order twice, so paid for shipping twice.
Over $500 in fittings for a simple loop... :P
https://linustechtips.com/topic/975249-best-soft-tubing/#findComment-11784250
Is that on the "White Haven" loop?  That turned out great.  Makes me question my move.
https://linustechtips.com/topic/975249-best-soft-tubing/#findComment-11784310
No, it's fittings that I ordered during the summer to do a full custom loop (which I haven't built yet)
Haven't upgraded my PC in a while.
https://linustechtips.com/topic/975249-best-soft-tubing/#findComment-11784316
Following this build because it's extremely similar to one I'd try to put together in my head for a while, but sadly wont get to any time soon.
https://linustechtips.com/topic/975249-best-soft-tubing/#findComment-11785761
