Hi, so I'm building a PC for my brother and I still have the case to decide on.
I would like a case that's:
• Compact and small, as my brother has very little room underneath his desk
• Able to fit an ASRock B450-M Pro4 motherboard
• Under £30 preferably as his budget is already hitting the ceiling
• Able to be purchased on Amazon UK
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
https://linustechtips.com/topic/972629-need-a-case-recommendation/
Just now, MatsNorway said:
Can you even get a case for 30 pounds? I guess used is the way to go.
I'd rather get some cheap case for under £30 than buy some used, grimy, dirty, scummy, dusty-ass decent-looking case.
I'm sure there are options out there for under £30, just have to find them.
I can't remember exactly how much it costs, but my brother has a Cooler Master N200, and it's a decent little case for the price.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
used Define R5/R4? there are plenty around and they tend to be in good nic for about that price or a little more. if you dont want a used case then just sort by cheapest on PCPP as nothing is going to be especially good and you are just picking the least worst one
Builds:
£57.06 on Amazon UK for a Cooler Master N200. :S
2 minutes ago, TVwazhere said:
Wow, thanks man!
I might just go with the Deepcool one, I have two of my NZXT case fans left over so I can easily install those onto the case. :)
