Triple monitor 4k gaming?
Raytheon 88
 I just ordered the RTX 2080 directly off of Nvidia website. Will this new card be enough to run triple 4k monitor gaming smoothly? Or am I just being unrealistic? I currently own triple 1080 monitors, but would like to upgrade to triple 4k monitors.
No one knows anything about these cards.
But even if, the upgrade in performance from 1080 to 2080 will probably be minimal.
Assuming performance is increase 5-10% better than the 1080, it will not run games very well, especially on 3 displays
If the benchmarks we've heard of so far come true, it will not run 4k games at all.
CPU: R5 3600 || GPU: RTX 3070|| Memory: 32GB @ 3200 || Cooler: Scythe Big Shuriken || PSU: 650W EVGA GM || Case: NR200P
What?
I skipped the 10xx series entirely. I upgraded from a 980>2080 and idk where you got 5-10% from, every article I've read states 25-30%.
Well 3840x2160x3= 24883200 (2488x3200)
As a non gaming display output resolution you'll be fine but for gaming, 2488x3200 is a lot of pixels to push. With no actual data on the performance of the card I can't tell you for definite but I doubt you'll be gaming on 3 4K displays.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
2 minutes ago, ErykYT3 said:
What?
There was a rumor of a benchmark for a game running in 1080p that was only getting around 50fps or something of the like
of course thats with RTX enabled, but still doesnt speak well for if its disabled
Put aside RTX for now, the "traditional" gaming performance we can make an intelligent guess on based on core count and clocks. It will be an improvement and a single card could finally deliver higher fps at 4k.
On the OP's desire to run 3x4k... not if you care about fps. At a guess, a 980 isn't that powerful anyway, so I'd assume running 3x1080p on it already requires lower settings to balance frame rates. How about splitting the difference, 3x1440p? Would still be a noticeable upgrade from 1080p without making the performance demands too high.
Also consider a single ultra-wide monitor. It isn't as wide as 3x 16:9 displays, but would it be sufficient? Would help take the load down a lot.
Gaming system: R7 7800X3D, Asus ROG Strix B650E-F Gaming Wifi, Thermalright Phantom Spirit 120 SE ARGB, Corsair Vengeance 2x 32GB 6000C30, RTX 4070, MSI MPG A850G, Fractal Design North, Samsung 990 Pro 2TB, Acer Predator XB241YU 24" 1440p 144Hz G-Sync + HP LP2475w 24" 1200p 60Hz wide gamut
Productivity system: i9-7980XE, Asus X299 TUF mark 2, Noctua D15, 64GB ram (mixed), RTX 3070, NZXT E850, GameMax Abyss, Samsung 980 Pro 2TB, random 1080p + 720p displays.
This thread seems really weird, time to clean some stuff up.
It is 5-10% better than the 1080TI  ,so 20-30% better than the normal 1080.
With raytracing on. You can turn the raytracing off and use it as a normal 1080ti(or very slightly better) card(so 4k high at 60 with a single monitor).
That is some very weird math. Your displays wont merge into one, also what? The real resolution would be 11520 x 2160. (3 4k monitors side by side)
And finally to the @Raytheon 88. The rtx 2080 will be about gtx 1080ti level of performance, so prepare to be dissapointed. The gtx 1080ti can't push a single 4k monitor at ultra graphics 60fps(i was really dissapointed at that), so you would have to put the graphics to low/very low to push 3x4k at over 30fps.
I agree with @porina, get a single ultrawide or ultra ultra wide monitor, then there wont be any annoying screen gaps too.
Image result for samsung 32/9 monitor
This is a Samsung 32/9 aspect ratio monitor.
I only see your reply if you @ me.
This reply/comment was generated by AI.
Yeah, don't know what I was trying to do there :)
زندگی از چراغ
Yeah, that part was especially weird: 24883200 (2488x3200)
What were you doing here? 2488 x 3200 = 7961600.
7 961 600 =/= 24 883 200
I just added this monitor to my Amazon wish list, thanks for the tip. Looks alot nicer than my current x3 27" 1080p monitor setup!
  • 4 months later...
Old thread - but..
I have 3 4k monitors running on a 1080 ti.  I can run most games at max settings around 30fps.
Games like shadow of the tomb raider i have to turn down to medium settings..  its mostly the shadows that cause frame reduction.
I am interested to see what kind of different a 2080 ti would make on my rig.  photo attached.
  • 3 weeks later...
On 1/20/2019 at 4:47 PM, Corpus said:
Old thread - but..
Sorry for resurrecting an old thread but a question. What monitors are those?
  • 2 weeks later...
