What is this cable and where do I plug it in
Hello I have the Corsair h150i and I have a weird cable from it here is a pic where do I plug it in
i presume that case has a built in fan controller, those are spots where you can plug in fans to be controlled by whatever controller the case has.
It has this in the back
Looks like you have an RGB controller and some kind of fan controller.
That connector in the first picture looks like it's for plugging a fan into. If it's just connected to your power supply, a fan plugged into it will work but run at full tilt all the time.
If you don't have any fans that aren't plugged into the motherboard or the fan controller, you can ignore that connector.
