Can I add a wire to carry wireless signal of a wireless router ?
Solved by Alex Atkin UK,
The thing is though, WiFi degrades a LOT over even good antenna cable.
Typical routers also have two or more antennas and you need to have at least two of them for optimal speeds.
Honestly, the cost of doing that (as you will need antennas too) would be greater than running an ethernet cable into the second room and using a dedicated WiFi access point in there. Plus the performance will be VASTLY better.
Featured Topics
aqarwaen29 ·
Posted in Storage Devices3 -
2
IR76 ·
Posted in Phones and Tablets10 -
1
4
SparkFox621 ·
Posted in Troubleshooting0 -
JJackson ·
Posted in Networking1 -
logan mcd ·
Posted in Graphics Cards4
