best gaming monitor?
Abzilla
hello all! I want to buy a monitor that is good for FPS e.g. BO4 and others like RDR2,
What i want from it:
Above 100Hz
between 30-35 inches
above 1080p (1440P or even 4K if it fits in the budget or goes a little over)
ideal if it works well with nvidia GPUs
and under £600 would be also be ideal (but could go a little over)
Thanks!
PC Specs: Motherboard: MSI Tomahawk X570  CPU: Ryzen 5900X  CPU Cooler: NZXT 240 mm Kraken Series AIO     GPU: Asus Strix ROG 1080 TI OC Edition    PSU: Corsair RM850 850W   Storage: 2 X 4TB, 2 X 1TB HDD And 1 X 1tb m.2 samsung 980 pro Case:  NZXT H440 2015 Edition
Above 100Hz
Thanks!
This one: ASUS PG279Q ROG
Asus PG279Q is pretty good for that price range.
Primary PC
CPU: AMD Ryzen 7 3700X | M/B: Asus ROG Strix X370-F | RAM: G.Skill TridentZ RGB 3200MHz 32GB | GPU: Asus TUF RTX 3070 8GB GDDR6 | SSD: Samsung 960 Evo 250GB | HDD: Seagate Barracuda 4TB x2 | Power: Thermaltake Toughpower 80+ Gold 650W | Sound card: Creative Sound BlasterX AE-5  | Case: NZXT H500 | Cooling: NZXT Kraken X62 | Display: Samsung CHG70 27" 1440p 144Hz QLED
Secondary PC
CPU: AMD Ryzen 5 5600 | M/B: Asrock B450M Pro 4 | RAM: Kingston HyperX Predator 3200MHz 16GB | GPU: Asrock RX 5700 8GB GDDR6 | SSD: Crucial P1 1TB | HDD: WD Black 1TB | Power: Coolermaster Masterwatt 550 | CaseAerocool Cylon Mini | Cooling: BeQuiet Pure Rock Slim 2 | Display: Samsung CFG73 24" 1080p 144Hz QLED
Thanks for reading
Both are the same except,
PG278QR is TN, while PG279Q is IPS.
so, PG278QR has better response time, while PG279Q has better color and viewing angle.
I would go for PG279Q.
Primary PC
Secondary PC
Thanks for reading
4 minutes ago, Hip said:
B, it's just 27" but there is nothing better than this in this price range in my opinion. WQHD 165Hz G-Sync and IPS.
https://www.amazon.co.uk/Samsung-LC32HG70QQUXEN-32-Inch-Curved-Monitor/dp/B071Z46XQT/ref=sr_1_1?ie=UTF8&qid=1534424035&sr=8-1&keywords=C32HG70
i just found this too, would this be better than the PG278QR and PG278QR?
Thanks by the way :)
Nope, because the ASUS monitor has G-Sync. That would reduce the input lag. You have a Nvidia card that would fit perfectly with that ASUS monitor.
I'd also say don't take a 32" monitor with WQHD. The display is more blurry than WQHD on a 27" screen.
ok thanks
I currently using it and it's amazing. but I recommend 27" ver. rather than 32" ver. I don't like 32" because it's too large. 27" is a sweet spot, plus it has more pixel density, and also cheaper, only 479.
Is it better than PG278QR or PG279Q? No. but at least it's cheaper.
Primary PC
Secondary PC
Thanks for reading
