Guys, I gotta be honest I'm feeling pretty dejected right now. Around this time last year, I built my first system with my own money. It was something I always wanted to do, an emotion I'm sure most of you share with me. This is my exact system specification: https://ca.pcpartpicker.com/list/pZ7nyX
After a while of using the Wraith Spire cooler, I upgraded my cooling solution to the Cooler Master MasterLiquid 240. The fans that the cooler comes with were absolute garbage, they made far too much noise from even from 1% fan speed all they way up. So I replaced them with Arctic F12s. Not the best upgrade, but they were super cheap so whatever.
Now for a while after I changed the fans, I had been acutely aware of my system still being quite noisy, in spite the replaced radiator fans! For the longest time (nearly a year I'll remind you), I had thought that the noise was just the Masterliquid pump being really trash at managing it's speed relative to CPU temps. And so I fiddled around with fan curves and plugging fans into the motherboard vs into a controller, I tried different thermal pastes, I even tried some different fans on the radiator.
On a whim, I decided to put my ear up to my system just to really confirm that the MasterLiquid pump was the source of this uncomfortable noise. To my shock, the source of the noise was actually the Cooler Master 550w Elite V2 power supply. Unbelievable.
I'm sorry for all this anecdote, but I had been incorrectly trying to troubleshoot this issue for a year, and due to my own ignorance, I spent a lot more money than I really needed to. I just needed to vent this somewhere :(
In hindsight, it makes a lot of sense, the Elite V2 isn't even 80+ rated, and its the lowest tier on the PSU tier list on this forum. (go figure)
TLDR
What I ask of everyone on the forum is some recommendations for a power supply that fits my system AND doesn't sound like a god damn jet engine while at idle. I certainly don't expect a silent PSU, but anything that's quieter than the Elite V2 is an improvement.
For a little more context, somewhat miraculously given the weak PSU, I'm running my R7 1700 overclocked, 3.875 GHz @ 1.3375 V.
**!!FOR FUTURE REFERENCE!!**
DO NOT BUY THE ELITE V2 UNLESS
A) You don't plan on overclocking anything
B) Your system draw is far below what the Elite V2 can deliver
C) You can get the thing for super super cheap, Like $20 or something
(even then I still highly recommend you just get something else, at least 80+ rated!)
Thanks for reading this everyone lmao, I appreciate any feedback!
https://linustechtips.com/topic/960381-power-supply-woes/
If you want setting pretty silent then the Bitfenix Formula is like $55 USD ATM (450w) and is good, if you need it to be even more silent then you are looking at a Bitfenix Whisper M or Corsair RMx which will run you anywhere from $70ish up to over $100...
Just some bapo nerd from 'Straya
PCs:
Main: i7 7700K (5GHz 1.4V) | ASUS GTX 1080 TURBO | 4x8GB Corsair Vengeance 3000MHz (3200MHz CL14 1.365V) | ASUS PRIME Z270-AR | Thermaltake SMART 750P | Coolermaster Seidon 240P | Acer Predator X34 (34" 1440p144Hz GSync IPS)
Secondary: i5 3570K | Intel HD4000 (RIP Sapphire HD 6850) | 2x2GB + 1x4GB Kingston 1600MHz | ASUS P8Z68-V LX | Corsair CX650 | Coolermaster Hyper D92 | Sony Bravia VPL-VW80 (108" 1080p60Hz projector)
Laptop: i7 7700HQ | GTX 1060 6GB MXM | 2x16GB SODIMM | OEM Acer Motherboard | 17.3" Screen (1080p60Hz IPS)
iMac: Core 2 Duo T7400 | ATI Radeon X1600 | 2x1GB 667MHz DDR2 | 20" Screen
https://linustechtips.com/topic/960381-power-supply-woes/#findComment-11646215
i've had to deal with a crap PSU before... when it blew up it took the motherboard, ram and an audio interface connected to that system out..
i suggest you stop using it for now if it's really that crappy, if it does blow up it could get expensive considering the rest of your components are still very good.
She/Her
Phone: OnePlus Nord CE 5G | 128GB | 8GB Ram
Main Desktop: Ryzen 5 3600 | GTX 1060 6GB | 32GB Ram
Main Laptop: Acer Aspire V3-771G | Core i7 3612QM | 16GB
https://linustechtips.com/topic/960381-power-supply-woes/#findComment-11646267
A Corsair RMx 550W is very, very quiet and might be in your budget. If not, then get an EVGA G2. Some people around here complain that it's too noisy but it's still the quietest thing in any system I've installed them in.
https://linustechtips.com/topic/960381-power-supply-woes/#findComment-11646275
I'll definitely keep those in consideration, thanks for your recommendation! I do want to keep the price down, but at this point cheaping out probably won't help my case...
https://linustechtips.com/topic/960381-power-supply-woes/#findComment-11646276
Is it really that unreliable?? Should I dial back my OC? Just run the R7 at stock?
https://linustechtips.com/topic/960381-power-supply-woes/#findComment-11646282
I've only ever seen good things said about Corsair units, definitely considering going Corsair. If it's quiet I'm happy!
https://linustechtips.com/topic/960381-power-supply-woes/#findComment-11646288
you said in your OP it's tier 7... so very bad. i definitely wouldn't overclock it until you get a better PSU...
i currently have an AX860. to me it's quiet, but i have 6 case fans and 2 cpu fans, and a power hungry gpu... so my definition of quiet might not be the same as yours. but i don't notice it. the rest of my system is louder than the PSU...
She/Her
https://linustechtips.com/topic/960381-power-supply-woes/#findComment-11646297
for clarification, the PSU that blew up on me was a different one than the one you have, but since then i'm never taking a risk with a psu again...
She/Her
https://linustechtips.com/topic/960381-power-supply-woes/#findComment-11646307
Just now, firelighter487 said:
for clarification, the PSU that blew up on me was a different one than the model you have, but since then i'm never taking a risk with a psu again...
At this point, If there's any risk at all I'm not willing to take it. I'm upgrading anyway so back to stock for me, for the time being at least. In terms of noise, The fan on this thing literally operates at what must be at 50% speed at idle. It's loud enough that I can still hear it quite clearly while listening to media on my closed back over ears.
https://linustechtips.com/topic/960381-power-supply-woes/#findComment-11646315
You shouldn't be running a dGPU or an octacore CPU on that unit at all, lol.
An overclock is like putting that PSU into an oven while doing it's job to the best of its ability.
https://linustechtips.com/topic/960381-power-supply-woes/#findComment-11646316
do you have a laptop or something? because i wouldn't risk running it at all to be honest...
like @STRMfrmXMN said, a unit like that is too crappy to use with this class of hardware...
She/Her
https://linustechtips.com/topic/960381-power-supply-woes/#findComment-11646320
I'm looking around, and Thermaltake, EVGA and Seasonic stuff is seems fairly reasonable in terms of price for me. What do you think of these units?
https://ca.pcpartpicker.com/product/6RTrxr/thermaltake-smart-600w-80-certified-semi-modular-atx-power-supply-ps-spd-0600npcwus-w
https://ca.pcpartpicker.com/product/nB3RsY/seasonic-power-supply-s12ii620bronze
https://ca.pcpartpicker.com/product/r2TPxr/evga-br-600w-80-bronze-certified-atx-power-supply-100-br-0600-k1
Also this Corsair Unit:https://ca.pcpartpicker.com/product/jZ22FT/corsair-vs-550w-80-certified-atx-power-supply-cp-9020171-na
https://linustechtips.com/topic/960381-power-supply-woes/#findComment-11646322
I don't have any other system to run on unfortunately, although I have been using this PSU for a year now. Certainly I don't want to continue using it, but as long as I don't push it beyond it's threshold, it should be serviceable at least, right?
https://linustechtips.com/topic/960381-power-supply-woes/#findComment-11646327
that psu that blew up on me was "500W" and all i ran on it was a Q9550 OC'd to 3.7ghz, and a GTX 1050. not enough to reach 500W i believe..
to be honest you are very lucky...
She/Her
https://linustechtips.com/topic/960381-power-supply-woes/#findComment-11646331
As much as I hate bet on luck, I'm just going to run my system at stock clocks and voltages, and wait a week or two until I can get another PSU. Hopefully nothing explodes :/ Wish me luck
https://linustechtips.com/topic/960381-power-supply-woes/#findComment-11646336
yeah good luck..
if your pc starts doing weird stuff unplug it right away...
when the psu that blew up on me died my pc turned off as if i unplugged it, and a few seconds later there was a big bang and that was that.. so if it does weird things unplug it.
She/Her
https://linustechtips.com/topic/960381-power-supply-woes/#findComment-11646341
It's not that Corsair units are inherently good; it's that Corsair has some units that we would recommend.
The first and last ones are super low end PSUs. The second one is ancient and known for not being particularly quiet. The third one has no reviews and a 30°C temp rating.
With an RX 580 you'll draw like 300W under load total, so just get the $80 Formula 450W.
https://linustechtips.com/topic/960381-power-supply-woes/#findComment-11646347
11 minutes ago, ExodusR said:
None of those are good.
The cheapest unit you should be looking at, especially considering you can afford an octa-core CPU and an RX 580, should be something like a Corsair CX450/CX450M or Cooler Master MasterWatt.
https://linustechtips.com/topic/960381-power-supply-woes/#findComment-11646351
So both of you guys are recommending 450W power supplies, but I still want to OC my 1700, and Seasonic's online PSU calculator gives me a number just above 500 watts. If I go with something in the Corsair CX line at a higher wattage should I still be okay? Also the Bitfenix Formula isn't available from any retailer in my region.
https://linustechtips.com/topic/960381-power-supply-woes/#findComment-11646362
All of the PSU calculators are useless and overestimate by a ton. You won't draw anywhere near 450W when overclocked, let alone 500W. With a 7820X and a 1080 Ti, you'll draw under 400W. With a Vega, under 500W.
Why are you using PCPP CA, then? What country will you buy from?
https://linustechtips.com/topic/960381-power-supply-woes/#findComment-11646372
I'm in Canada, southern Ontario to be specific. Also I double checked and the Formula actually is available on Newegg in my region, my bad. Just for future reference, what could I expect the same system to draw if instead of an R7 1700, it was an R5 1600 @ 3.8 gHz @ 1.35 v and an AIB R9 290? I'm thinking about building a system for a friend in the future and repurposing some old hardware.
https://linustechtips.com/topic/960381-power-supply-woes/#findComment-11646382
The RX580 is only going to be drawing about 200W. Even with the most insane CPU overclocks, the Asrock AB350's VRMs would melt before you could deliver anywhere near 250W to the CPU.
Even PCPartPickers calculator taking in to account HDDs, fans, and peripherals (but not CPU overclock) puts your system at 415W.
That said, just grab a Seasonic Focus Plus Gold 550W or Corsair RM550x, since both of the Focus Plus Gold and RMx product ranges start at 550W anyway.
https://linustechtips.com/topic/960381-power-supply-woes/#findComment-11646383
A 1600 at that voltage and a 290 I would expect about 400-450W under load.
https://linustechtips.com/topic/960381-power-supply-woes/#findComment-11646386
I remember hearing Steve from Gamers Nexus saying good things about Seasonic. I'm definitely considering Seasonic alongside Corsair.
https://linustechtips.com/topic/960381-power-supply-woes/#findComment-11646395
