Help re-enabling thumbnail cache
There's the changes:
2018-07-23 20:33:15,216 : Setze Registry-Key HKLM\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer\NoThumbnailCache -> 1
2018-07-23 20:33:15,216 : Setze Registry-Key HKLM\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer\DisableThumbnailCache -> 1
2018-07-23 20:33:15,232 : Setze Registry-Key HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced\NoThumbnailCache -> 1
2018-07-23 20:33:15,232 : Setze Registry-Key HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced\DisableThumbnailCache -> 1
Though it just added these to the registry, but you don't need to delete these keys.
2018-07-25 17:41:53,451 : Lösche Registry-Key HKLM\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer -> NoThumbnailCache
2018-07-25 17:41:53,454 : Lösche Registry-Key HKLM\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer -> DisableThumbnailCache
2018-07-25 17:41:53,462 : Lösche Registry-Key HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced -> NoThumbnailCache
2018-07-25 17:41:53,464 : Lösche Registry-Key HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced -> DisableThumbnailCache
2018-07-25 17:43:19,154 : Lösche Registry-Key HKLM\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer -> NoThumbnailCache
2018-07-25 17:43:19,156 : Lösche Registry-Key HKLM\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer -> DisableThumbnailCache
Open Start, type Regedit and enter.
Navigate through the folder to these locations and change only these keys:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer\NoThumbnailCache -> 0
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer\DisableThumbnailCache -> 0
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced\NoThumbnailCache -> 0
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced\DisableThumbnailCache -> 0
There is also an easier way to navigate to those registry keys. By just coping this the directory location:
Paste that in the top bar of Registry Editor and hit enter and you will be brought to the location.
When you are at that location you will see a bunch of keys, the one you want are "NoThumbnailCache" and "DisableThumbnailCache". Double click on the name of those keys and you will be presented with a box that tells you to type the Value data in, then type in 0 in the box and hit OK.
Then do the same with this:
