How does metal corrotion work
Solved by TVwazhere,
7 minutes ago, JorgeSuarez said:I don't get it, if mixing metals like copper and aluminum is a bad thing, why do some companies just send aio coolers with a copper waterblock and a aluminum radiator?
AIO manufacturers fill their coolant with a lot of anti-corrosives and completely seal them, so they actually tend to last quite a while. Longer than the pump anyways, which is usually the reason you'd ever get rid of an AIO for a defect.
(Video starts at relevant point)
