I need help deciding what to get for a gaming rig
Solved by Ordinarily_Greater,
go for the i5 upgrade kit, it will still be a good CPU to game with. But why would you change your current i5-4690K?
That Haswell chip will perform as good as a 8th gen core i3
to be honest you will need a Graphics Card upgrade only
Featured Topics
Rogue57Chevy ·
Posted in Graphics Cards0 -
Ricodotsh ·
Posted in Power Supplies0 -
2
bloodknightoo ·
GreenGDK ·
Posted in Troubleshooting1 -
RLT_Byers ·
Posted in Peripherals1 -
1
13
Triggeravus ·
Posted in Graphics Cards2 -
Aden101 ·
Posted in Laptops and Pre-Built Systems1
play_circle_filled
Latest From Linus Tech Tips:
I Will NOT Give You $250 for Your Broken Game - WAN Show April 26, 2024
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
