Hey everyone, a few days ago I bought a Canon Eos M3.  Photos look fine but video looks grainy and glitchy on my Dell Monitor. I have attached a screenshot from the video and the photo. For the Sky, video was taken at 1080p, 25fps, ISO 800, F5.6. Photo was taken with the same ISO ,aperture but with 1/20s shutter speed.
Taken as photo
Screenshot from video
Main Desktop:
Intel Core i7-13700KF (5.5GHz, -0.1v Offset), Lian Li Galahad 360 AIO, Asus ROG Strix Z790-A Gaming WiFi, Gigabyte RTX 4070 Ti Super Aero OC, 2x16GB G.Skill Trident Z5 RGB DDR5-6000 CL36, 4TB Samsung 990 Pro, Corsair RM850x Shift, Phanteks NV5 w/ Lighting Kit
Peripherals:
Alienware AW3423DWF QD-OLED, Logitech G502 X Plus, SteelSeries Aerox 3 WL 2022 Snow, HiFiMan Sundara, Sennheiser HD 560s, Cooler Master MH630, Schiit Modi 3e, Schiit Magni Heresy
Laptops:
Asus ROG Zephyrus G14 (Ryzen 9 8945HS, RTX 4060)
Phones:
Samsung Galaxy S24 Ultra 256GB, iPhone 14 Plus 128GB
https://linustechtips.com/topic/925494-eos-m3-noise/
Here's another Photo: ISO 800, F5.6, 1/8. Video: ISO 800, F5.6, 1080p 25p
Main Desktop:
Peripherals:
Laptops:
Phones:
https://linustechtips.com/topic/925494-eos-m3-noise/#findComment-11328565
what is the shutter speed you use for the video?  25p is just framerate, do you use 1/25 or 1/50 or 1/something for shutter speed? and do not equalize ISO for photo like ISO for video with some cameras.  for photo the EOS m3 is capturing 24megapixels anmd for video it is taking the sensor resolution and scaling down to 1080p resolution.
yeah what would i know about cameras or cinematography compared to you tech people.  i've only done this work for nearly 20 years, won a few awards, worked in over a dozen different countries and a few multi million dollar projects
https://linustechtips.com/topic/925494-eos-m3-noise/#findComment-11331193
I don't know if the low light video capabilities on the M3 is any better. To get the most out of the video quality, I'd lower the ISO to the native 100. If you need more light, use a lower shutter speed, on 25p, I'd personally use 1/50, and open your aperture to the widest possible. If f5.6 is as low as you can go with your lens, consider buying a prime lens f2.8 or even f1.4. Also, shooting in good lighting conditions is the best way to improve content quality.
I don't think there is something wrong with the camera, but in most cases, at any camera, you'd get less noise on stills, compared to video.
https://linustechtips.com/topic/925494-eos-m3-noise/#findComment-11336418
The shutter speed in the video is the same as the photos. Don't know much about cameras btw, just my first venture into the world of photography.
Main Desktop:
Peripherals:
Laptops:
Phones:
https://linustechtips.com/topic/925494-eos-m3-noise/#findComment-11341239
I can't seem to bring the ISO below 200 though. And I just realized I can use f3.5 but still a bit grainy.  I commonly film in places where there isn't as good lighting as maybe outdoors or studio lighting. Maybe it's time for me to up my photography skills lol.
Main Desktop:
Peripherals:
Laptops:
Phones:
https://linustechtips.com/topic/925494-eos-m3-noise/#findComment-11341248
That is weird, I haven't got the camera myself, but looking up the specs, it seems like it would be possible to set the ISO to 100. I also recommend using shutter speed 1/50, nothing less, and if you shoot in low light, you don't want to go any higher neither.
There is also an option where you can use your editing software to do noise reduction. Be careful, when you use the effect, you might blow out details if you push it too far.
https://linustechtips.com/topic/925494-eos-m3-noise/#findComment-11341498
Thanks, will try that later on. But I'm just wondering what exactly caused that graininess. It's sorta bugging me now ? If someone could suggest the cause of it please do so. Thanks. FYI, it's still grainy even outdoors where there's a decent amount of light
Main Desktop:
Peripherals:
Laptops:
Phones:
https://linustechtips.com/topic/925494-eos-m3-noise/#findComment-11341730
Noise is apparent on every digital camera, especially when shooting in low light. It is the sensor which receives electrical noise from other sources than the photons.
When we use a higher ISO, we are amplifying the signal we receive from the light photons. Unfortunately, as we amplify the signal, we also amplify the background electrical noise that is present in any electrical system.
In low light, there is not enough light for a proper exposure and the longer we allow the image sensor to collect the weak signal, the more background electrical noise it also collects. In this case, the background electrical noise may be higher than the signal.
The M3 has a small image sensor, which often is more sensitive to noise than other formats.
Each photosite itself generates electrical noise that can contaminate its neighbor. In a larger image sensor, the photosites can be physically further apart and thus be less affected by that contamination.
A larger image sensor also means that the photosite can be larger, thus have a larger light gathering capacity. It is therefore able to generate a larger signal to noise ratio.
Source: http://www.photoxels.com/tutorial_noise.html
https://linustechtips.com/topic/925494-eos-m3-noise/#findComment-11341865
video camera in low light usually records video that looks very noisy and is especally worse with the code/compression in your camera
https://linustechtips.com/topic/925494-eos-m3-noise/#findComment-11341946
Video is lower resolution than pictures, so I think noise will be more apparent on the video.
I don't. Know if that's the reason tho.
“Remember to look up at the stars and not down at your feet. Try to make sense of what you see and wonder about what makes the universe exist. Be curious. And however difficult life may seem, there is always something you can do and succeed at.
It matters that you don't just give up.”
-Stephen Hawking
https://linustechtips.com/topic/925494-eos-m3-noise/#findComment-11342992
