Ryzen 2600 - Motherboard Recommendation Required
Solved by nithin1992,
7 hours ago, dave_k said:ye, the krait will suffice, although X470 Gaming Plus would be better
Thanks for the response. The X470 are also priced pretty high and are not really an option. Although I thought the MSI X470 Gaming Plus and the X370 Krait had the same VRM, is it not?
I’m going for the Krait in the next hour or two, unless someone says otherwise.
