Hi. I've recently build a new pc, and my gpu is to arrive by mail soon. Its the Gigabyte AORUS GeForce GTX 1080 Ti Waterforce WB Xtreme Edition 11G GeForce GTX. Looking for advice, i've never done this before. Do i need a certain case? I have this one https://de.pcpartpicker.com/product/svVBD3/fractal-design-case-fdcadefsbk
https://linustechtips.com/topic/922859-my-first-water-cooling/
Define S is an exelent watercooling case, you are fine with that one for sure :D
Builds:
https://linustechtips.com/topic/922859-my-first-water-cooling/#findComment-11303321
Watercooling a gpu is also effective. Your temps will be great (assuming you setup your loop properly) You take cards that even with custom coolers hit 80c and turn them into nice cool 35-40c beasts. Not only that but you have more control over where the heat is dumped. Instead of having it dump into your case and causing turbulence with your case air flow, you can have it either dumped outside of the case or have it receive fresh ambient air.
https://linustechtips.com/topic/922859-my-first-water-cooling/#findComment-11303426
2 hours ago, Professor Smoothie said:
So.. i'm looking to just cool my gpu with liquid. What is recommendable? Also not looking to pay too much.
What is not to much? Anyway, you'll need a radiator, pump, reservoir, some fittings and tubing.
For the radiator I would recommend a 240mm one. That's enough for only a GPU.
Get a good pump. A D5 or DDC one is preferable as those pumps are strong enough if you want to expand your loop later on.
Fittings, here it gets a bit tricky as it depends on the type of tubing you go with and the inner and outer diameter of the tubing.
Watch some video's from JayzTwoCent's channel on YouTube.
CPU: i7-12700KF Grill Plate Edition // MOBO: Asus Z690-PLUS WIFI D4 // RAM: 16GB G.Skill Trident Z 3200MHz CL14
GPU: MSI GTX 1080 FE // PSU: Corsair RM750i // CASE: Thermaltake Core X71 // BOOT: Samsung Evo 960 500GB
STORAGE: WD PC SN530 512GB + Samsung Evo 860 500GB // COOLING: Full custom loop // DISPLAY: LG 34UC89G-B
https://linustechtips.com/topic/922859-my-first-water-cooling/#findComment-11305057
7 minutes ago, Professor Smoothie said:
Arent there any premade water cooling systems that is a complete package?
Yes there are but as far as I know they also include a CPU block.
It's better to go with a custom loop though.
What's your budget by the way?
https://linustechtips.com/topic/922859-my-first-water-cooling/#findComment-11305147
29 minutes ago, Professor Smoothie said:
I'd say 150 to 200 euros should be the max.
That's a tight budget. For example:
- Radiator €71: https://www.ekwb.com/shop/ek-coolstream-pe-240-dual
- Pump/reservoir combo €142: https://www.ekwb.com/shop/ek-xres-100-revo-d5-pwm-incl-pump
and then you'll need some fittings, tubing and fluid which'll be another 30-50 or so. Watercooling isn't cheap unfortunately. Having the block come with the cards saves you another ~150 though (but that's probably already included in the card's price somehow).
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
https://linustechtips.com/topic/922859-my-first-water-cooling/#findComment-11305333
If your budget allows, then you should get a P240- kit, that'll give you everything you need for your GPU look  and a CPU block that you could expand to in the future with just 2 more fittings and a radiator.
https://www.ekwb.com/shop/ek-kit-p240
The L240 kit is a cheaper alternative but comes with a pretty "meh" pump and, so your money will be well spent on the P240 kit instead.
https://www.ekwb.com/shop/ek-kit-l240-1
https://linustechtips.com/topic/922859-my-first-water-cooling/#findComment-11305371
What about something like this? https://tweakers.net/pricewatch/764141/nzxt-kraken-x62-(met-am4-support).html i'm not planning on expanding in the future, i just got this gpu for a good price but gotta cool it somehow.
That's an AIO, not to be designed to be incoorporated into a custom loop. There are many reasons why that is not compatible, so that will not work.
https://linustechtips.com/topic/922859-my-first-water-cooling/#findComment-11306202
58 minutes ago, Professor Smoothie said:
Why do i need a custom loop?
Because your graphics card has a full cover waterblock on it. There is no cooling on it unless you have water pumping through it, and a radiator to dissipate that heat.
GV-N108TAORUSX WB-11GD
https://linustechtips.com/topic/922859-my-first-water-cooling/#findComment-11306511
Look ak EKWB's A240G. It has a waterblock and backplate for GPU and has a cpu block. Its 250$ US
Case: InWin 303 Motherboard: Asus TUF X570-Plus Processor: Ryzen R9-3900x GPU: Gigabyte RTX 3070 Ram: 32 GB DDR4 3000 MHZ
 PSU: Corsair CX750M Storage: 1TB Intel 660p NVME SSD and a 2TB Seagate 7200RPM HDD Mouse: Logitech G600 Keyboard: Razer Blackwidow Ultimate 2014 HeadphonesSteelseries Arctis 7 Audio: Shure PGA58 with a Focusrite Scarlett Solo 3rd Gen
https://linustechtips.com/topic/922859-my-first-water-cooling/#findComment-11306622
And that is an aluminium kit, the gpu has a copper block, definitely not compatible.
https://linustechtips.com/topic/922859-my-first-water-cooling/#findComment-11306699
Huh
Kit is aluminum
Block is copper
GREAT IDEA TOTALLY (op don't do this it will screw up your card)
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/922859-my-first-water-cooling/#findComment-11308033
42 minutes ago, Professor Smoothie said:
Is there anything i need besides this kit?
If you're happy with soft tubing and not having a drain port, then there is nothing else you need apart from the standard stuff like a screw driver and a pair of scissors.
https://linustechtips.com/topic/922859-my-first-water-cooling/#findComment-11309161
  • 1 month later...
So i managed to get it all done, finally. Thanks for the help everyone.
Now a couple of questions..
The fans seem to ramp up and down for no reason, even in idle. And they are much louder than my regular fans.
I had to use a split cable to get them connected to the mb.
Is it recommended that i get another fan to dissipate more heat? When i'm gaming there tends do be a lot of heat coming from the back fan. Currently i have `1 fans on the front sucking fresh air in, one in the back blowing hot air out. And, 2 fans on the radiator that's heating the case basically.
https://linustechtips.com/topic/922859-my-first-water-cooling/#findComment-11466538
