Water cooling MOSFETs necessary to achieve 5 ghz OC on 8700K?
Solved by WereCat,
There is absolutely no reason to watercool the mosfets on any half-decent motherboard.
Even slight airflow is usually enough, just make sure you have enough airflow in that area and you are set.
Featured Topics
CurtisLee14 ·
Sparky862 ·
Posted in Storage Devices1 -
1
tinpanalley ·
Posted in Networking0 -
DoughmanX_HD ·
Posted in Windows1 -
220VoltsallCore ·
Posted in Operating Systems4 -
Ridoheru ·
Posted in Graphics Cards1 -
