1080 ti barely does not fit in case
kage65
Got a 1080 ti and because of the power cables I cannot put the side cover on. It does not clear by maybe one inch. Should I get a new case? If so which one? I just need a wider case, not necessarily a taller one. Thanks.
lol I'm like ''transparent side panel? how cute'' when I left out mine because the PSU wont fit in.
Desktop benching:
You can just be me and leave the side panel off.
Then dust your card every 2 months lol
Just now, Legendarypoet said:
EVGA makes this thing.
Lol I'd forgotten about that thing. Pretty much exactly what OP needs.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
Just now, ModuleLFS said:
That is actually pretty nice.
It's also $20 for what's effectively a dongle.
Computer Specs:
Yeah, definitely an $8 item, but I don't see anything else like it, so they've got the "only one" tax.
Glad my gpu has connectors on the side, don't know what are manufacturers thinking putting them on the front of the card, it rarely looks good that way.
Mine has them on top as well. And it's a really tall PCB for a 480. But hey, I got it because of the amazing cooling solution (inaudible at 68C while mining), not because of practicality.
Computer Specs:
I though that only worked for standard Pcbs, may be better off begging a cable extension or just bend the cables down.
I’d get a different card before a case.
Main RIg Corsair Air 540, I7 9900k, ASUS ROG Maximus XI Hero, G.Skill Ripjaws 3600 32GB, 3090FE, EVGA 1000G5, Acer Nitro XZ3 2560 x 1440@240hz
Unfortunately you can't bend down the cables. What is standard Pcbs?
Standard would be reference. Judging by the dual 8 pin I assume it isn’t.
Its 8 pin to 8 pin. I'm thinking it will work (?)
No, Dongle's DO THINGS, at the very least least converting pinouts.  That's a very short, very ridgid extension cable... For $20. o____o
#420blazeit :P
Well, it's like on the edge of being a dongle while looking fancier than an extension cable. Still though, it's $20.
You can just bend the cables hard and hope they don't break.
Computer Specs:
Either bend those cables (the heat shrink will be tough but it will bend... safely) or get yourself a pair of 8pin extenders. Tons of companies make pretty extenders like cablemod or just buy a $1 version off of an Asian amazon seller.
1 hour ago, kage65 said:
The Evga thing could work but looks like it may still be too wide. I guess something like this could work?
https://www.amazon.com/Degree-Right-Angle-Female-Inverted/dp/B0749C32X6
yep that will work, get 2 of course
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
How would an extender work? Tks
15 minutes ago, Jay Deah said:
This is a 6 pin version but you can see how it works from the picture. Will give you a few extra inches of cable without that solid heat wrap
https://www.amazon.co.uk/StarTech-Express-Power-Extension-Cable-Black/dp/B004ZMYBAE
yiu can also get pretty braided versions from companies like cablemod
So you are saying with these I will be able to bend the cable down enough to get the case side cover on? These look preferable as they ship prime while it looks like the other ones ship from China.
Tks
yes thats what im saying. you have the nice bendy bit flugged into the card and the solid bit will be out of the way somewhere more convenient.
BUT...
why bother, just bend the cables, the heat shrink is only plastic, it will bend (unplug cable first tho, dont bend anytihg else like the gpu/pci slot :)
Heating up the heat shrink a bit when bending it will make it much easier to bend, and make it stay that way once cooled...
·Ï¢årµ§·
i7 4790k · 32GB Kingston HyperX · MSI Gaming 5 · ... · 30" HP ZR30W + 27" Samsung 275T · 2x240GB Intel 530 in Raid 0 + 2x1TB Crucial MX500 · Lain-Li X2000F · Antec Signature SG-850 · BeQuiet! Dark Rock 3 Pro · Logitech Z5500 · Win10pro 64bit
