Asrock x399 Tai Chi WiFi not working
ISUther
I have windows 10 installed.
I never used wifi on desktop pc but now i need to use it.
When i unplug LAN cable i see this this icon on bottom left corner:
When i go to "Start" >> "Control Panel" >> "Network and Internet" >> "Network and Sharing Center" >> "Change advanced sharing settings" >> I have "Turn on network discovery" enabled.
As far as i know i should get available WiFi connections visible when i clikc on the WiFi icon on bottom right corner.
Tho i have not installed any special drivers or software regarding the MB.
Just turn on wifi by clicking the wifi button.
Current LTT F@H Rank: 90    Score: 2,503,680,659    Stats
Yes, I have 9 monitors.
My main PC (Hybrid Windows 10/Arch Linux):
OS: Arch Linux w/ XFCE DE (VFIO-Patched Kernel) as host OS, windows 10 as guest
CPU: Ryzen 9 3900X w/PBO on (6c 12t for host, 6c 12t for guest)
Cooler: Noctua NH-D15
Mobo: Asus X470-F Gaming
RAM: 32GB G-Skill Ripjaws V @ 3200MHz (12GB for host, 20GB for guest)
GPU: Guest: EVGA RTX 3070 FTW3 ULTRA Host: 2x Radeon HD 8470
PSU: EVGA G2 650W
SSDs: Guest: Samsung 850 evo 120 GB, Samsung 860 evo 1TB Host: Samsung 970 evo 500GB NVME
HDD: Guest: WD Caviar Blue 1 TB
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Other: White LED strip to illuminate the interior. Extra fractal intake fan for positive pressure.
unRAID server (Plex, Windows 10 VM, NAS, Duplicati, game servers):
OS: unRAID 6.11.2
CPU: Ryzen R7 2700x @ Stock
Cooler: Noctua NH-U9S
Mobo: Asus Prime X470-Pro
RAM: 16GB G-Skill Ripjaws V + 16GB Hyperx Fury Black @ stock
GPU: EVGA GTX 1080 FTW2
PSU: EVGA G3 850W
SSD: Samsung 970 evo NVME 250GB, Samsung 860 evo SATA 1TB
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity)
Case: Sillverstone GD08B
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
Details: 12GB ram, GTX 1080, USB card passed through to windows 10 VM. VM's OS drive is the SATA SSD. Rest of resources are for Plex, Duplicati, Spaghettidetective, Nextcloud, and game servers.
click the gray button that says wifi and wait a minute.
My Rig
CPU - Ryzen 5 1600@3.8ghz          GPU - XFX XXX RX580 8g          Cooler - Arctic Freezer 33 eSports edition green          Motherboard - Gigabyte AB350 Gaming 3          Ram -  G.Skill 2x8 Ripjaws 5 2666                   Case - Pahntecs P400s TGE Modded with Green accents          PSU - Seasonic M1211 evo 620w          SSD - Samsung 960 evo 500 GB          HDD - Seagate Barracuda 7200rpm 2tb
 Fans - 2 be quiet SilentWings 3         OS - Windows 10 Home 64-Bit         Cables - Cable Mod Green Cable Extension
 Peripherals
Mouse - Logitech G502          Keyboard - k95 Platinum Brown          Headset - Philips SHP9500s + Vmoda Boom Pro          Monitor - LG 29UM69GB
Webcam - USB webcam for Wii Fitness game xD
Nope, Nothing happens and does not work. No errors.
I made small video.
25 minutes ago, ISUther said:
Is it an Intel Wireless Adapter? There's a known issue with the drivers that I think assumes you have an intel CPU, so you have to make a correction there
Make a Thread on the Level 1 Forums with the title, something like that, the issue is with the driver if I'm not mistaken
Intel Wireless Adapter on Threadripper / X399
https://forum.level1techs.com/
I have it installed and it is set to ON but problem remains :(
Your problem seems to be exactly the same as mine (I just got a new ASRock X399 motherboard).
One of these two actions, or both, may solve your problem. Download and install the ASRock WiFi Connector Utility form the Asus website. Reboot and select "On" from the little antenna looking thing that appears in the system tray (this software seems to act as a mechanical button does on a laptop.)
Download and install the Intel Wireless Proset Utility (or some similar name) for the Intel AC 3168 chip on a 64 bit Windows 10 machine (at least these are the specs on my machine. Get this at the Intel website.
Doing these two things fixed my problem.
Good luck,
Got it working.
Had to re-install the utility.
Some how it was buggy before but now works as intended.
  • 1 month later...
There is a simpler solution. Go to bios, change the wifi from auto to enabled!
  • 4 months later...
I'm having the same problem with mine. No wifi and no bluetooth. I can't seem to install or find the wifi utility connector too. I've tried everything, downloaded all the drivers, reinstalled windows, turned it on and off in the BIOS.. nothing works.
Can someone give me a link or installer for the wifi connector utility?
  • 1 year later...
Had to do a lot of searching for my solution to this issue; exact same symptoms that OP reported and documented on his video. ASRock WiFi Connector Utility does not seem to be available anymore,  so I could not go that route.
In my case the WAN was set to "Auto", which seemed to not work right within Windows 10. Switching it from auto to "Enabled" solved the issue for me. Reference this video for where to find the location for the WAN setting within the BIOS.
https://youtu.be/LCsIzhnVYnY
