Low cost monitor help with G-Sync
STRESSMASTER
My son is complaining that a ton of screen tearing is happening and I do know that it is from having the video card (GTX 750 ti 4Gb) (old 4:3 dell 15" monitor) sending more FPS that the current monitor is setup for.
First how would I go about putting a global (all apps/games) FIX in place
Second What is the best 1080p g-sync monitor for the cheapest possible. i.e. best price point but hopefully under $250 USD
Thanks
PSU Tier Ranking List
Ryzen 5 1600x|ASROCK                      |16GB DDR4 3400Mhz Corsair Vengence   | (partial build in progress)
FX-8350 AM3+| ASUS M5A990FX V1 | 32GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 850 PRO | Win 7 64 Pro | EVGA 750W G PSU | EVGA 750 ti 6GB | Corsair H100i v1
FX-8120 AM3+| ASUS M5A990FX V2 | 16GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 850 PRO | Win 7 64 Pro | EVGA 750W G PSU | EVGA 750 ti 6GB | Corsair H80i v1
I5-2500K LGA  | ACER MOBO??         | 16GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 860 PRO | Win 10 64 Pro | EVGA 750W G PSU | EVGA 970 SC 4GB | Corsair H80i v1
Vsync will probably solve it as far as a all game/app fix I think in the Nvidia control panel their should be a force vsync option (99.9% of monitors are 60hz so pick that) Wish I could be more specific but don't have any Nvidia gpus atm. As for gsync your best bet would be to buy used most gsync monitors new are in the $300-400 range
R7 2700x (4.3ghz), Gtx Titan Xp Galactic Empire (Watercooled), 2x8 Gskill Trident 3200mhz, Asus Crosshair VII Hero Wifi, Corsair 900D, SAMSUNG 960 PRO M.2 256gb, Samsung 850 evo 500gb, 4x3tb 7200rpm Segate Barracudas in Raid 10 EKWB Custom Loop, Corsair AX1500i Power supply
I will try that thanks.
22 minutes ago, STRESSMASTER said:
G-sync is a waste of money
Just enable V-sync, a frame cap, or use Fast Sync preferably which only works if you stay above your monitor's refresh cap
If you want a better monitor in general, there are solid free-sync options at $200 and under, could potentially move to a Ryzen APU rig in the future to make use of free-sync, but that likely isn't worth it.
Either 1080p 75hz IPS (my pick)
or 1080p 144hz TN
PCPartPicker part list: https://pcpartpicker.com/list/nvn86X
Price breakdown by merchant: https://pcpartpicker.com/list/nvn86X/by_merchant/
Monitor: AOC - G2460PF 24.0" 1920x1080 144Hz Monitor  ($197.12 @ Amazon)
Monitor: LG - 24MP59G-P 23.8" 1920x1080 75Hz Monitor  ($149.99 @ Amazon)
Total: $347.11
Generated by PCPartPicker 2018-02-16 00:32 EST-0500
I was think V-sync tbh already but would like something around 27-30 inches. any recommendations for that?? (bigger not necessarily better but want the best $$/value)
Unless the display is going to sit pretty far away 27" or larger for 1080p doesn't make much sense.
It is also used for Stream/tv watching via PC and games about 50%/50%
So how far away does the display need to sit? because that the size will change. There are some options in that size range for 1080p IPS monitors, but normally it makes no sense to buy them.
G-Sync wise your much better off getting a slightly smaller 24' monitor than a 27' monitor at 1080p. https://www.amazon.com/Acer-Predator-XB241H-bmipr-1920x1080/dp/B01C05C1OK/ref=sr_1_1?ie=UTF8&qid=1518760489&sr=8-1&keywords=g-sync+monitor+144hz+1080p
Your saving around $200 for 3 inches of monitor, it just sucks how much g-sync monitors cost in general.
Thanks all I can say is WOW double the cost for 2 inch nuts. But if I can do Vsync than would a 27 be ok?
and $150 more than the same type of display with free-sync
Thus why G-sync is a waste of money.
