Mining is killing me. Need graphics.
Go to solution Solved by Damascus,
3 minutes ago, TVG33K said:
Any advice with that?
Use gpu userbenchmark to compare cards and try r/hardwareswap
I obviously do not have a monster budget. I have been saving for a graphics card, and right when I had enough for a 1050 ti, mining came along and made it cost as much as a 1060. Is there ANY way I can get a 1050 ti or an equivalent for about 130-140 dollars? I just want to play games with high settings in 1080p at 60 fps. Surely the 1050 ti could to that. Even the AMD equivalents are getting really pricey
https://linustechtips.com/topic/894227-mining-is-killing-me-need-graphics/
970/980/780Ti
SPECS: Intel Core i5-4460 // PowerColor Red Dragon RX 480 4GB // 1x8GB DDR3 RAM // Delta 500AB-6A PSU // HyperX Cloud Stinger / Logitech G710+ / Logitech G502 / Xbox One Halo Guardian controller // LG 24M45H 1080p //
How to cope with depression
Spoiler free review of Life is Strange (Video Game)
sadly here even secondhand 970's go for 200+ :(
your best bet if you really need one now for that budget is a secondhand 780Ti sadly.
Just wait it out Nvidia appears to be prepping a new architecture, and cryptocurrencies are crashing, the market will (hopefully) flooded with cards soon.
In search of the future, new tech, and exploring the universe! All under the cover of anonymity!
Probably not, as the 1050ti is probably going to go up.
You know with dram pricing going up etc.
Damn you samsung and your price fixing.
I don't know if they're doing it now or if it's demand but samsung has done it before so yeah.
Shady.
There is, look for GTX 960 or R9280/285/280x/380/380x on the used market like ebay. Also HD 7870. They vary in their performance but they're your best shot at a reasonably priced graphics card.
Or wait out the shortage, it's going to end at some point as the market stabilizes around prices that aren't as enticing for miners.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
Gtx:
980 (1060 level)
780 ti/970/titan/titan black (in between 1050 ti and 1060)
960/770/780/680 (1050 ti ish)
AMD
290/290x/390/390x (1060 level)
7870/280x/7970/7950 (1050 ti ish)
Want to custom loop?  Ask me more if you are curious
Okay. This is good. Now one more thing while I dig through more cards. Will having a 2gb card mean that I won't be able to play in high settings for most games due to lack of VRAM? I think medium settings are okay, but high would be a plus
2gb gets a bit limiting, my brother has a 770 2gb and it runs out of vram on total war harhammer.
Most of these cards have higher capacity versions, if at all possible aim for them.
2GB of Vram will be a limiting factor going forward, and you will more than likely start to run out of Vram in certain games at high settings.
Gaming PC: i5 8600k @ 4.8GHz | 16GB T-Force Delta RGB @ 3200Mhz | Asus Prime Z370-A | Sapphire Radeon VII (Dead :( ), RX480 8GB | EVGA SuperNova 750 G2 | 120GB Sandisk SSD Plus, 120GB Kingston A400 | 4TB Seagate 7200RPM , 1TB WD Blue 7200RPM | Phanteks P400 Windows 10, MacOS Catalina
Second PC: i5 3340s @ 2.8GHz | 8GB Corsair Vengeance @ 1333MHz | EVGA 750Ti SC | Cheap £7 250GB WD HDD Windows 7
LaptopLate 2009 MacBook (Core 2 Duo, 4GB Ram, 120GB SSD, 9400m, running Mojave) , Late 2013 MacBook Pro Retina (i5, 4GB Ram, 128GB SSD)
Consoles: Xbox One, PS4 Slim, PS3 slim, Xbox 360 fat still going strong after almost 10 years, Original Xbox, PS2, PS1
Phone: Realme 6, Xiaomi Mi A2, Xiaomi Redmi Note 4x, iPhone 6s (jailbroken)
Tablet: iPad Mini 2nd Gen Retina (Jailbroken)
Headphones:  Hifiman HE4xx, Phillips Fidelio X2, Status Audio CB-1,  Fiio E10k DAC, Schiit Magni 3+, Tin T2 IEM's, Astrotec S80
Keyboards:  2x Custom 60% - 1x Gateron Yellow, 1x Box Reds
Thank you for all the help. The only place I am finding good deals is with the radeon hd cards. I do not know how they are organized, the date that they came out does not seem to make a difference, their performance is all over the place. Last question I promise. Any advice with that?
If you think GPU prices will come back down again to the point they were, you're in for a rude awakening. I'm guessing a $50-100 premium will forever be added to GPU's now. Just like with all the high memory capacity GPU's. They were selling midrange GPU's for $400+ before the mining bubble.
they will, just not immediately, though whenever volta comes out they'll print out gpu's for that architecture and that will help fill demand of both miners and gamers alike
Sorry to hijack the topic but i was wondering how much would an RX480 sell for (without warranty) It's new it was just bought abroad so no papers. Would it even be worth selling it? Thought i could upgrade but i'm worried i won't find anything to buy :D
Bitcoin value is tanking right now, so i'd wait out a little longer and see how things play out. Might find a bunch of current gen 2nd hand cards flooding in.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
Oh they'll come down, but not to where they were.
Right now is the absolute worst time to buy graphics cards dude. Wait. I'm sitting on a 965m for ~3 years now, it's glitching out on me but I'm waiting because I REFUSE to give Nvdia $400 more for a entry level graphics card.. I hope the bitcoin market crashes to the fucking ground. Then the used market place will be flooded, Nvdia will have to lower their prices to compete with the used market and we will then be happy.
Hopefully Bitcoin and the other coins crash soon. Fuck em
What if i just sell the rx480 and sit on the money
Depends, do you have another GPU to rely on? Or do you mind not having a GPU for a while?
To be honest predicting if the cryptocurrency market is gonna crash is no easy task. The price has dropped by half the last couple of days, but it's somewhat back to normal now.. There's no real way to predict bitcoin since it's just so unpredictable.. and the people that try are almost always wrong. They predicted the crash so many times, and so many called they said bullshit.
Don't expect the bitcoin market to crash tomorrow..
GTX 770 4gb variant... should be able to find one used for around $120, a very capable card for 1080p gaming till this day. The one I had purchased 5 years ago is still trucking along even playing some PUBG.
AMD Ryzen 1700x
ASRock x370 Taichi
Corsair Vengeance RGB 16GB GDDR4 3200
EVGA GTX 1080 Ti K|NGP|N
Fractal Meshify C
Samsung Evo 960 Nvme M.2 500gb & WD Blue 1TB
Corsair TX850M Gold
Alienware AW2518H 240Hz Gsync
Audioengine A2+ & Sennheiser HD6xx /w Fiio K5 Pro
Deepcool Captain 240Pro V2
Vortex Race 3 Cherry Mx Red
Corsair Vengeance M65 PRO RGB
Probably going to have to go with a GTX 780.
Main Gaming PC (new): HP Omen 30L || i9 10850K || RTX 3070 || 512GB WD Blue NVME || 2TB HDD, 4TB HDD, 8TB HDD ||  750W P2 ||  16GB HyperX Black DDR4
Main Gaming PC (old, still own) : Intel Core i7 7700K @5.0Ghz || GPU: GTX 1080 Seahawk EK X || Motherboard: Maximus VIII Impact || Case: Fractal Design Define Nano S || RAM : 32GB Corsair Vengeance LPX
Cooling: EK XRES D5 100mm || Alphacool ST30 280mm w/ Vardars || Alphacool ST30 240mm w/ Vardars || Swiftech 3/8 x 1/2'' Lok-Seal Compressions || Swiftech EVGA Hydrocopper Block || Primochill Advanced LRT Orange || Distilled Water
Folding@Home Rig: 2x X5690s @4.6Ghz || GPUs: 2x Radeon HD 7990 || Motherboard: EVGA SR-2 || Case: Corsair 900D || RAM: 48GB Corsair Dominator GT 2000Mhz CL9
Ethereum Mining Rig: Pentium G4400 || Gigabyte Z170X-UD5 TH || 2x GTX 1060s (Samsung & Hynix) 1x GTX 1070 (Micron), 2x RX480s BIOS modded (Samsung), 1x R9 290X 8GB, 1x GTX 1660 Super = ~ 195 Mh/s
Peripherals: 3x U2412M (5760x1200), 1x U3011 (2560x1600) || Logitech G710 (Cherry Blues) || Logitech G600 || Brainwavz HM5 with @Gofspar Mod
Laptop: Dell XPS 15 || "Infinity Edge" 4K IPS Screen || i7 7700HQ || GTX 1050 || 16GB 2400Mhz RAM
I feel bad for you, I got a GTX 1050 Ti for $123 during Black Friday. :/
Quote
  • My PC - Ryzen 3 1200 @ 3.6Ghz // ASRock AB350M Pro4 AM4 // Ripjaws V Series 16GB(2 x 8GB) DDR4-2666 // WD Caviar Blue 1TB 7200RPM // Zotac GTX 1050 Ti 4GB //  EVGA 450W 80+
