Does cm vertical gpu mount fit in master case 5t?????!?!?!?
Solved by NumLock21,
13 minutes ago, >( .____.) said:Ok, so it is compatible
Yes it's compatible.
http://www.cmstore-usa.com/vertical-graphic-card-holder-with-riser-card/
Featured Topics
tippytipper ·
Posted in Storage Devices1 -
2
AlyShazli ·
Posted in New Builds and Planning11 -
4
Emmanuel Katto ·
Posted in Peripherals3 -
3
2
Rusty Proto ·
5
WildOne ·
Posted in New Builds and Planning2
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
