Help: M.2 SSD & Motherboard
Salvinz
Hello everyone!  Long time lurker, first time poster.  A quick brief, I'm a PC gamer who is far more comfortable in dealing with software than hardware.  Boxing day will be coming up soon and I'm looking to finally shift towards SSD's.  I've done some reading, however, I am in need of help, specifically around pairing certain SSD's with my motherboard.  I'm uncertain of optimal settings and this is where I need your expertise.  To anyone that's able to point me into the right direction, thank you so much!
System Specs:
CPU:  Intel Core i5-6600K @ 3.50GHz
Motherboard:  Z170A GAMING M5 (Bios 1.60)
Memory:  16384 MB
GPU:  GeForce GTX 1060 6GB
HDD x 2:  Western Digital WD Green 1TB 5400 RPM 64MB Cache SATA 3.0Gb/s 3.5"
OS:  Windows 10 Pro
PSU:  Corsair HX 650w
Goals:
I've just purchased one Crucial MX300 525GB (https://tinyurl.com/ya5jmd9h) and looking into getting another Crucial MX300 525GB or a Crucial MX300 525GB M.2 (https://tinyurl.com/y7hgtb8f).  I'd like to get the M.2 but I'm not sure exactly what I'll be giving up.  Will my GPU be slower?  Will I have to sacrifice both of my 1TB WD's?  I'd much rather have my setup be optimal than be functional at sub-optimal settings.  I did go through my motherboard manual but as I mentioned earlier, I'm not hardware inclined.  Attached to this post is my motherboard manual; I believe the relevant info is on page 34.
Thank you so much for any help!  Happy holidays...  :)
7977v1.0(G52-79771X1)(Z170A GAMING M5).pdf
I personally don't see why you would need 2 SSDs, I'd just get one SSD for some applications and then use the HDD(s) for mass storage. That said, I don't think you'll lose any GPU speed adding a second SSD
As a gamer you don't need M.2 speeds.
Get an SSD.
Samsung for your boot drive.
Quote
CPU-AMD Ryzen 9 5900X / CPU Cooler-Noctua NH-D15S / Motherboard-MSI MPG X570S CARBON MAX WIFI / Memory-G.Skill Trident Z Neo 64 GB (4 x 16 GB) DDR4-3600 CL16 / Storage-WD WDBSLA0040HNC-NRSN 4TB 3.5" 7200 RPM / Storage-WD Red 6 TB 3.5" 5400 RPM--Crucial P3 4TB 3.0X4 NVME--Sabrent Rocket 4.0 1TB 4.0X4 NVME--Corsair MP600 CORE 2TB 4.0X4 NVME / Video Card-XFX Radeon RX 6900 XT / Case-Lian Li O11 Air Mini / PSU-SeaSonic PRIME 1000 W 80+ Gold / Sound Card-Creative Labs Sound Blaster Z w/Shield / Monitor-BenQ GW2765HT 27.0" 2560 x 1440 60 Hz / Monitor-Asus ROG Strix XG27AQ 27.0" 2560 x 1440 170 Hz / Keyboard-Logitech G Pro / Mouse-Logitech G502 LIGHTSPEED Wireless / UPS-CyberPower GX1325U / Fan Controller-Corsair Commander Pro
Quote
CPU-AMD Ryzen 7 5800X / CPU Cooler-Corsair iCUE H100i ELITE CAPELLIX / Motherboard-Asus TUF GAMING X570-PRO (WI-FI) / MemoryG.Skill Trident Z Neo 32 GB (4 x 8 GB) DDR4-3600 CL16 / Storage-Western Digital Black SN750 SE 1TB 4.0X4 NVME--Samsung 970 Evo Plus 2TB 3.0X4 NVME--Seagate Barracuda Compute 3 TB 3.5" 5400 RPM / Video Card-Asus KO Gaming OC GeForce RTX 3070 / Case-Lian Li O11 Air Mini / Case-LIAN LI PCI-E 16 X 4.0 Black Riser / PSU-EVGA SuperNOVA 850 G+ Gold / Monitor-LG 22BK430H-B 21.5" 1920 x 1080 60 Hz / Monitor-MSI Optix 271CQP 27.0" 2560 x 1440 165 Hz Curved / Keyboard-Logitech G413 TKL SE / Mouse-Logitech G502 HERO Wired / UPS-CyberPower CP1350PFCLCD / Fan Controller-Corsair  Commander Pro / Sony HT-S200F Soundbar
Quote
CPU-AMD Ryzen 7 5700X / CPU Cooler-Scythe Mugen 5 Black Edition / Motherboard-MSI MPG B550I GAMING EDGE MAX WIFI / Memory-G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 CL16 / Storage-Samsung 970 Evo Plus 1TB 3.0X4 NVME--PNY CS900 1TB 2.5" SSD--Samsung 970 Evo Plus 2TB NVME/ Video Card-EVGA XC GAMING GeForce RTX 3060 / Case-Cooler NR200P / PSU-Cooler Master V750 SFX GOLD / Keyboard-HyperX Alloy Origins Core / Mouse-Logitech G502 HERO Wired / UPS-CyberPower LE1000DG-FC / Fan Controller-NZXT RGB & Fan Controller
Quote
CPU-AMD Ryzen 7 5700G / CPU Cooler-Scythe Shuriken 2 / Motherboard-Gigabyte X570 I AORUS PRO WIFI / Memory-Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3800 CL18 / Storage-WD Blue 1TB 2.5" SSD--Samsung 970 Evo Plus 1TB 3.0X4 NVME--Patriot P310 1.92TB 3.0X4 NVME / Case-InWin B1 Mesh / Keyboard-Logitech K380 / Mouse-Logitech G502 LIGHTSPEED Wireless / Monitor-ViewSonic VX1755 17" 1080p Portable IPS Gaming Monitor 144Hz / Speakers-Creative Muvo Go (Black)
Thanks for the info Crunchy Dragon.  As for my needing two drives, I like to compartmentalize to keep things organized.  Given that, I keep one drive for Windows OS and OS related applications and have the other drive(s) be for gaming, videos etc.
Get an SSD.
Understood... What if I was looking to install Windows on the M.2 and have the 2.5" SSD for games; would that be possible in my setup?
Sure, I have a similar set up.
On my MB sata ports 5 & 6 are disabled when I use an M.2
so check your MB manual for that.
Quote
Quote
Quote
Quote
Thanks for getting back to me wONKEyeYEs!  Looking at my motherboard manual and as I understand it, I can look forward to this setup: 1xM.2 SATA SSD + 4xSATA HDDs?  In essence, I can hook up one M.2 2280, one 2.5" SSD and two HDD's?
Yes, it looks like if you put your sata m.2 in the M2_1 slot for example
you will have sata ports 3, 4, 5, and 6 available.
Quote
Quote
Quote
Quote
Much appreciated!  So now that I'm squared away on that important bit of info, there is a small complication.  More than likely, I'll have to plug the M.2 into the second available slot as the first slot has both the GPU and a giant CPU cooler nearby.  Now, I'm hoping that the second M.2 slot is a twin and I would loose no functionality by plugging into it.  Again, thanks so much for your help so far wONKEyeYEs.
Cheers :)
Edit:  I just realized my mistake by looking at the graph again.  Answered my question.  xD
Get an SSD.
M.2 has nothing to do with speed, it's simply a connection.
Cheers :)
I'd just check to make sure that you lose the same ports. Often if you're using a different m.2 port, different SATA ports will be affected, but you shouldn't lose any. If you're putting only Windows and a few programs on the boot drive I'd look into NVME depending on the size you get. You get small speed improvements, but it's often not much more than a SATA drive at lower capacities.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
So my SATA SSD can transfer at the same speed as my 960 EVO NVMe M.2?
Wow, I did not know that.
<sarcasm off>
Quote
Quote
Quote
Quote
<sarcasm off>
I'll say it again, and hope you realize your error.
M.2 has nothing to do with speed. SATA vs M.2? Yes. You can, however, have either in the M.2 form factor.
Just now, dizmo said:
I'll say it again
Oh, well in that case i concede. xD
Quote
Quote
Quote
Quote
Appreciate all the info everyone.  Since my original post, I've read as much as I can about this.  As I understand it, getting the Crucial MX300 525GB M.2 as opposed to the Crucial MX300 525GB wouldn't offer any gains, i.e., they're both identical in performance and differentiate themselves in only form factor.  Given that, I've been looking at the Samsung 960 EVO 500GB (https://tinyurl.com/ydggrkfs) as this should offer me actual gains.
I'm fairly certain of it's compatibility with my Z170A GAMING M5 (https://tinyurl.com/ybv98vfu) motherboard but I wanted to get a second opinion, just in case I'm missing something.  My understanding so far, M.2 has three keys: B, M or B+M.  B keys offering up to 10GBits/s as opposed to 20GBits/s from the M keys, and the B+M keys are flexible form factors.
In my case, the Z170A has the M key and it's 2280, so I shouldn't run into any compatibility issues with the Samsung 960.  If I've missed anything at all, please feel free to correct me.
Thanks!  :)
