Blown capacitor on gpu
Solved by Changis,
3 minutes ago, WindowsXP16 said:I have fixed the formatting issue.
The damage only stopped the fan from working, I have used the GPU for the past 2 days but unplugged it now just in case.
The card is an Sapphire R7 360 and it is about a year old. I have overclocked it using the AMD software.
you bought the card new a year ago? because it was released 2.5 years ago, so i wouldn't wait to long if you can RMA it. i'm assuming you still have the receipt?
anyway, good luck atleast, i have a feeling that most likely they will conclude user error due to overclocking or see that the cooler was removed (thermal paste) and refuse rma.. then again i might be wrong..
