PSU fan periodically stopping - how big of an issue?
Solved by Stefan Payne,
1 hour ago, zorrito said:Title. Should i buy a new PSU ASAP? Should i stop using my pc altogether until I do? I'm not planning on changing the fan as I don't want to risk anything. I don't have the warranty papers but it's a 2-3 year old PSU.
Here's a video showing the problem in action
What PSU is it?
What components?
Pls make picture of the PSU label and upload it to this forum.
You also might want to make a picture of the PSU connectors on the motherboard, if possible with the connectors.
The fan seems to die soon so you should replace the PSU as soon as possible.
