Monitor went grayscale even after factory reset
Solved by Ryois,
If you're using Windows 10 try doing
Windows Key + CTRL + C
that will disable Greyscale in Windows
Featured Topics
Tamgam12 ·
Posted in New Builds and Planning10 -
3
Blizzforte ·
Posted in Programs, Apps and Websites7 -
Amzadd ·
Posted in CPUs, Motherboards, and Memory8 -
GreenLeaf ·
Posted in Troubleshooting10 -
Pirateben ·
Posted in New Builds and Planning2
