bottleneck RX 580 worse performance than GTX 1050 using Pentium G4560
Solved by Morgan MLGman,
4 hours ago, Vizent said:I know I need a CPU upgrade, I just can't afford it. The thing that weird is, is that the performance of RX 580 is worse compared to GTX 1050. How can I atleast get the same fluidity as I used to have?
My current monitor is within buyers mind changing time so I can trade it for free with a FreeSync monitor for free. I just don't know if it's worth all the effort of trading it in....
Definitely switch to a FreeSync one, do it as fast as you can as it's a huge upgrade for you - trust me.
As for getting more stable performance, I believe you can try GPU resolution upscaling via GPU drivers or locking the FPS to a value like 60FPS. Those should at least help lower the CPU usage in games.
