IPS vs TN monitor.
Brony
So I want to get a 1440p monitor for gaming that's not an ultrawide and is less than $800, however if I can save money while getting the preformance I want, if be happy to save some cash. What I have now is a basic 1080p monitor that has a 60 hertz refresh rate, so an upgrade to 1440p would look a lot better to begin with. What I want from this new monitor is a 144 hertz refresh rate and it has to have g sync seeing as I have a 1080ti. Now I'm not too familiar with IPS vs TN, but I know that IPS has better colors but a 4ms response time usually. A TN monitor had worse colors but has a 1ms response time. I'll be playing AAA title games in 1440p, but I'm no graphic designer, so do I really need the colors to "pop" and have a 4ms response time, or have the colors not be as sharp and have 1ms response time? Thanks guys.
The reality of it is, you really won't notice the difference in response times, whereas better colors are immediately noticeable by anyone (and on a large TN monitor you may actually experience color shift even while directly in front of it). However, as far as I know there are very few 144hz gsync IPS monitors and they are very expensive, so if money is a problem you may want to stick with TN.
sudo chmod -R 000 /*
i have the IPS 1440p Gsync monitor and it's great, but dell has this TN for like nearly half the price right now...and IMHO it's better to save the money, IPS look better but it has light bleed in the corners and the blacks aren't that great...i would rather spend less for the TN personally.
And above all else i would say buy an Oculus Rift instead as it's a lot better...or get the TN and the money you saved could go torward an oculus rift+touch bundle.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 2 VR
i personally own a 27 inch 1440p 144hz  gsync monitor by acer and it's paired with a 1080ti. I could not be happier. it's going to last me a long time. i've owned TN panels in the past, but switching to IPS was the best thing i ever did and i will never go back to tn. backlight bleed is only noticeable when your screen is completely black, which is almost never the case.  when you are gaming, things are moving fast on your screen with bright colors so you will never notice backlight bleed. i understand this is case by case and it can be worse based on the manufacturing process and luck of the draw, but i've never been able to notice it unless my screen is black. i've also never been able to notice a difference between 1ms or 4ms response times and my competitive gaming scores have never suffered from the difference.
the pros of a tn monitor are the faster response time.
 and usually lower cost
the cons of a tn monitor (compared to IPS) worse viewing angles
 -worse color accuracy
the pros of an IPS monitor are: better color accuracy
 -better viewing angles
cons of IPS: higher cost
-backlight bleed(usually a non-issue except in extreme cases)
-higher response time (not noticeable unless a professional gamer)
for me, IPS is a no brainer. having better color accuracy and viewing angles is HUGE for gaming, watching movies and videos, and editing photos. it makes things so much more immersive and exciting.
 I WILL NEVER GO BACK TO TN!!
It's really personally preference but I'm a huge fan of IPS. The colors just look so much better. Also don't worry too much about response time, 1ms to 4ms is basically unnoticeable. I don't think it's ever been done but I would be surprised if even professional gamers would be able to pick which is which in a double-blind test. The colors on the other hand are very noticeable and to me look way better.
I have a 1440p, 144Hz, G-sync IPS and my buddy has a 1440p 144Hz G-sync TN and when placed side by side I can tell no difference in performance but the colors and viewing angles are massively better on the IPS.
Primary PC-
CPU: Intel i7-6800k @ 4.2-4.4Ghz   CPU COOLER: Bequiet Dark Rock Pro 4   MOBO: MSI X99A SLI Plus   RAM: 32GB Corsair Vengeance LPX quad-channel DDR4-2800  GPU: EVGA GTX 1080 SC2 iCX   PSU: Corsair RM1000i   CASE: Corsair 750D Obsidian   SSDs: 500GB Samsung 960 Evo + 256GB Samsung 850 Pro   HDDs: Toshiba 3TB + Seagate 1TB   Monitors: Acer Predator XB271HUC 27" 2560x1440 (165Hz G-Sync)  +  LG 29UM57 29" 2560x1080   OS: Windows 10 Pro
Album
Other Systems:
Home HTPC/NAS-
CPU: AMD FX-8320 @ 4.4Ghz  MOBO: Gigabyte 990FXA-UD3   RAM: 16GB dual-channel DDR3-1600  GPU: Gigabyte GTX 760 OC   PSU: Rosewill 750W   CASE: Antec Gaming One   SSD: 120GB PNY CS1311   HDDs: WD Red 3TB + WD 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200 -or- Steam Link to Vizio M43C1 43" 4K TV  OS: Windows 10 Pro
Offsite NAS/VM Server-
CPU: 2x Xeon E5645 (12-core)  Model: Dell PowerEdge T610  RAM: 16GB DDR3-1333  PSUs: 2x 570W  SSDs: 8GB Kingston Boot FD + 32GB Sandisk Cache SSD   HDDs: WD Red 4TB + Seagate 2TB + Seagate 320GB   OS: FreeNAS 11+
Laptop-
CPU: Intel i7-3520M   Model: Dell Latitude E6530   RAM: 8GB dual-channel DDR3-1600  GPU: Nvidia NVS 5200M   SSD: 240GB TeamGroup L5   HDD: WD Black 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200   OS: Windows 10 Pro
Having issues with a Corsair AIO? Possible fix here:
Are you getting weird fan behavior, speed fluctuations, and/or other issues with Link?
Are you running AIDA64, HWinfo, CAM, or HWmonitor? (ASUS suite & other monitoring software often have the same issue.)
Corsair Link has problems with some monitoring software so you may have to change some settings to get them to work smoothly.
-For AIDA64: First make sure you have the newest update installed, then, go to Preferences>Stability and make sure the "Corsair Link sensor support" box is checked and make sure the "Asetek LC sensor support" box is UNchecked.
-For HWinfo: manually disable all monitoring of the AIO sensors/components.
-For others: Disable any monitoring of Corsair AIO sensors.
That should fix the fan issue for some Corsair AIOs (H80i GT/v2, H110i GTX/H115i, H100i GTX and others made by Asetek). The problem is bad coding in Link that fights for AIO control with other programs. You can test if this worked by setting the fan speed in Link to 100%, if it doesn't fluctuate you are set and can change the curve to whatever. If that doesn't work or you're still having other issues then you probably still have a monitoring software interfering with the AIO/Link communications, find what it is and disable it.
Highly recommended get the IPS panel or VA panel. TN is my prohibited panel.
TN panel how great still looks not that great even straight view on it compare with IPS. They is heaven (IPS) and hell (TN) when comparing it.
Unless you use monitor in total dark condition or dark condition, else IPS glow or light bleeding never an issue. If this is the situation, I suggest go for VA panel. They is no light bleeding issue, no IPS glow issue,  pure black. Sometimes I find VA panel is the best in between, just off course accuracy in color still IPS wins and viewing angle still IPS better.
They is only one type of panel can take over IPS in future - OLED panel.
The respond time of 5ms or below is far than enough, the 1ms in TN is not that necessary and you won't notice that much.
PC: AMD Ryzen 9 5900X, Gigabyte GeForce RTX 4090 OC 24G, X570 AORUS Elite WIFI Motherboard, HyperX FURY 32GB DDR4-3200 RGB RAM, Creative Sound Blaster AE-9 Sound Card, Samsung 970 Evo Plus M.2 SATA 500GB, ADATA XPG SX8200 Pro M.2 SATA 2TB, Asus HyperX Fury RGB SSD 960GB, Seagate Barracuda 7200RPM 3.5 HDD 2TB, Cooler Master MASTERLIQUID ML240R ARGB, Cooler Master MASTERFAN MF120R ARGB, Cooler Master ELV8 Graphics Card Holder ARGB, Asus ROG Strix 1000G PSU, Lian Li LANCOOL II MESH RGB Case, Windows 11 Pro (22H2).
Laptop: Asus Vivobook "A Bathing Ape" - ASUS Vivobook S 15 OLED BAPE Edition: Intel i9-13900H, 16 GB RAM, 15.6" 2.8K 120hz OLED | Apple MacBook Pro 14" 2023: M2 Pro, 16 GB RAM, NVMe 512 GB | Asus VivoBook 15 OLED: Intel® Core™ i3-1125G4, Intel UHD, 8 GB RAM, Micron NVMe 512 GB | Illegear Z5 SKYLAKE: Intel Core i7-6700HQ, Nvidia Geforce GTX 970M, 16 GB RAM, ADATA SU800 M.2 SATA 512GB.
Monitor: Samsung Odyssey OLED G9 49" 5120x1440 240hz QD-OLED HDR, LG OLED Flex 42LX3QPSA 41.5" 3840x2160 bendable 120hz WOLED, AOC 24G2SP 24" 1920x1080 165hz SDR, LG UltraGear Gaming Monitor 34" 34GN850 3440x1440 144hz (160hz OC) NanoIPS HDR, LG Ultrawide Gaming Monitor 34" 34UC79G 2560x1080 144hz IPS SDR, LG 24MK600 24" 1920x1080 75hz Freesync IPS SDR, BenQ EW2440ZH 24" 1920x1080 75hz VA SDR.
Input Device: Asus ROG Azoth Wireless Mechanical KeyboardAsus ROG Chakram X Origin Wireless MouseLogitech G913 Lightspeed Wireless RGB Mechanical Gaming Keyboard, Logitech G502X Wireless Mouse, Logitech G903 Lightspeed HERO Wireless Gaming Mouse, Logitech Pro X, Logitech MX Keys, Logitech MX Master 3, XBOX Wireless Controller Covert Forces Edition, Corsair K70 RAPIDFIRE Mechanical Gaming Keyboard, Corsair Dark Core RGB Pro SE Wireless Gaming Mouse, Logitech MK850 Wireless Keyboard & Mouse Combos.
Entertainment: LG 55" C9 OLED HDR Smart UHD TV with AI ThinQ®, 65" Samsung AU7000 4K UHD Smart TV, SONOS Beam (Gen 2) Dolby Atmos Soundbar, SONOS Sub Mini, SONOS Era 100 x2, SONOS Era 300 Dolby Atmos, Logitech G560 2.1 USB & Bluetooth Speaker, Logitech Z625 2.1 THX Speaker, Edifier M1370BT 2.1 Bluetooth Speaker, LG SK9Y 5.1.2 channel Dolby Atmos, Hi-Res Audio SoundBar, Sony MDR-Z1R, Bang & Olufsen Beoplay EX, Sony WF-1000XM5, Sony WH-1000XM5, Sony WH-1000XM4, Apple AirPods Pro, Samsung Galaxy Buds2, Nvidia Shield TV Pro (2019 edition), Apple TV 4K (2017 & 2021 Edition), Chromecast with Google TV, Sony UBP-X700 UltraHD Blu-ray, Panasonic DMP-UB400 UltraHD Blu-ray.
Mobile & Smart Watch: Apple iPhone 15 Pro Max (Natural Titanium), Apple Watch Series 8 Stainless Steel with Milanese Loop (Graphite).
Others Gadgets: Asus SBW-06D2X-U Blu-ray RW Drive, 70 TB Ext. HDD, j5create JVCU100 USB HD Webcam with 360° rotation, ZTE UONU F620, Maxis Fibre WiFi 6 Router, Fantech MPR800 Soft Cloth RGB Gaming Mousepad, Fantech Headset Headphone Stand AC3001S RGB Lighting Base Tower, Infiniteracer RGB Gaming Chair
