Poor College Wifi Signal (on mobile phone)
3 Lions
Hi guys,
So I've just started another term of college and with it a wifi signal problem, I only noticed this issue today by the way. My problem is when I'm in the main part of the college the signal is very erratic what I mean by this is the single drops in and out every few seconds and doing a speed test reveals very poor results (10ms Ping, 11.01 Mbps Download & 25.49 Mbps upload) but the thing is when I go over to a separate building of the college my download gets about 62 Mbps which was the speed I normally got around the whole college before I broke up for the term break. Can anyone think of things I could do to stop this? (all other mobile devices in the main area of the college don't have this issue).
Thanks
Edited by LinusTechTipsFanFromDarlo
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
Unless you install tinder, I don't think the wifi will help you not being single anymore :/ sorry.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
check if you wireless adapter is able to automatically change channel width or channels
your wireless is prob using a channel which is congested with other devices sharing the same wifi hotspot
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
I didn't notice that at first, changed now though :)
زندگی از چراغ
Yep it does get busy with other users but like I said it was never like this before I broke up for the term break.
زندگی از چراغ
did you update the wireless adapter driver?
what adapter you are using on the laptop?
Oh it not a laptop, it's a mobile phone (Sony Xperia XZ Premium)
Just made it more clear in the title.
زندگی از چراغ
Does you phone has the 5GHz band for wifi? Technically the phone will hop between the channels.
I could only say is try to forget the network and then try adding the hotspot back.
Yes it does have a 5GHz band and I've tried forget the network but hasn't done anything.
زندگی از چراغ
You mentioned it only just one area right? Does it happen with other places?
No only in the main part of the college, as I said I can go over to a separate building (still on the same site) and get stable wifi and decent speeds.
زندگی از چراغ
Wireless coverage or just the hotspot
You cant do much on your part.
You can use those app wifi scanner and see how is the performance of the wifi in the affected area.
Okay thanks anyway :)
زندگی از چراغ
